Question about Kenwood KDC-135 CD Player
Kenwood KDC 122 wont play
Radio/cd were working fine. Suddenly the receive stopped makig sounds,  when I was listening to my iPod through a Fm Transmitter. The Cd was ejected. The receiver no longer plays on FM, AM or CD. The power fuse is ok. When I turn on the receiver the insert disc light flashes and if I insert a CD it just rejects it. If I put the headlights on which lights the dash lights all the radio lights flash  at about a 2 second rate. If I turn the thumb wheel control on the dash lights all the way up so that the overhead lights come on, the receiver lights stop flashing.
I have tried the reset button but still no joy. I guess I will have to remove it and make sure that there is power at the receiver itself. It is installed in a 1986 Fiero which means that it is not easy to get at. Any suggestions would be appreciated.
Cheers ....Dave
Posted by DaveDude17 on
  • rachel1234 Dec 25, 2007
    i also have a kdc 122p and it was working fine a few days ago and now when i insert a cd it just spits it back out. it sounds like it doesnt take it in all the way or soemthing..but i honestly have no idea considering i dont know how to work the thing. it came in my car when i bought it used a year ago and was obviously installed. it always worked good until like a week ago. :-\ suggestions?
4 Related Answers
Anonymous
SOURCE: No response from the KDC-519
I once had the same problem and took it in to have it looked at! The guy simply pushed in the small black button to the left of the ATT button and it reset!
Hope that helps!
Posted on Nov 21, 2007
Anonymous
SOURCE: KENWOOD RADIO
take a pen and press the reset button ...it's a tiny little button next to the button that takes off the faceplate...
Posted on Mar 15, 2008
makemelaugh
  • 4 Answers
SOURCE: Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Posted on Jul 03, 2008
SQUIRESXX
cock cock
  • 486 Answers
SOURCE: Radio does not turn on, and can not eject cd.
HAVE YOU REPLACED UNIT? IF YOU HAVE THEN IT COULD BE THE SWITCHED / CONSTENT FEED BEING AROUND THE WRONG WAY, YOU CAN TEST TO SEE IF YOU HAVE A CONSTENT FEED WITH IGNITION OFF ON ONE OF THESE, AND A FEED ON THE OTHER YOU TURN IGNITION ON, THE THESE ARE NORMALLY RED AND YELLOW SWAP THEM ROUND, GROUND/EARTH IS BLACK, FUSE N HEAD UNIT NORMALLY BEHIND THE PLUG THAT FITS IN THE HEAD UNIT
Posted on Dec 06, 2009
Can you hook up and ipod to this KDC 105?
i dont think so you can always get a fm moduelator. it will take a empy channel and play your music though the radio
Apr 06, 2010 | Kenwood KDC-105 CD Player
Why wont my kenwood kdc-122 display light up
chances are you have bad solder connections inside the radio.
Apr 01, 2010 | Kenwood KDC-122 CD Player
Kenwood kdc mp 232 how do I get to the aux when
turn the ipod off why would you want it on not listening to it anymore?
Jan 15, 2010 | Kenwood KDC-MP232 CD Player
Cd will not play displays E4
Page 22 displays error code descriptions and suggested remedies for your Kenwood KDC-122 CD Player. This is a link to Kenwood site and instruction manual.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC2022.pdf
Yes, the KDC-122 is included in this document.
Oct 26, 2009 | Kenwood KDC-122 CD Player
Kenwood KDC-MP538U - no sound.
My issue was that I didn't have the blue "amp" wire hooked up and I had a factory amp.
Jan 06, 2009 | Kenwood KDC-MP538U Car CD/ MP3 Player
GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Sep 18, 2008 | Kenwood KDC-W3037A CD-receiver,...
No AM long wave radio
The antenna wire could be loose.
Jul 17, 2007 | Kenwood KDC-3021 CD Player
Satellite No Longer An Option on My Kenwood KDC-MP228
Your going to need to pull off the battery cable for about 2 to 5 minutes and see if this will reset the radio. Good Luck
Mar 23, 2007 | Kenwood KDC-MP228 CD Player
Kenwood KDC-135 CD Player Logo
111 people viewed this question
Top Kenwood Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
