I have tried a number of different settings including all the profiles and have customised by own but I can only make the phone vibrate. When I view the default sound library I can select each track or sound but when I click on the play icon there are still no sounds. Please help.
SOURCE: phone wont play ringtone with incoming call eventhough one is selected will spell out number calli
with the phone closed, goto tools, voice commands....click on settings in the lower right.......scroll down to call alert.......change to ring only or caller id+ring....on the env that should solve your problem
SOURCE: LG Secret SMS text alerts sounding only once
In the settings change the interval to continuous.
SOURCE: lg renoir phone - sound issue
You are in the right place but looking at the wrong option, if you scroll down on the Normal profile you will see a message tone option, if you are not hearing a tone at the moment then I suspect it will say "No Sound". Tab this option and select Existing sound, you will then be able to navigate through the sound files on your phone and choose one of the Default Sounds (from the folder by the same name) or an MP3 or other supported sound file you have added to your phone.
If that doesn't solve your problem then you may have a faulty phone.
You can change the sound you get when sound alert is switched on by going to Settings > Touch Settings > Touchscreen Effect and choosing a different sound from the Tone option. You can also change the volume of the tone of severity of touch vibration here.
SOURCE: voyager cell no sound
1. Power you phone off then take out the battery. Put it back in and turn it back on. Rebooting every once in awhile will delete any corruptions or locked up features. You should do this once a week when you remember.
2. If that does not resolve it. Change your ringtone save the changes and change it back. Change your volume level and change it back.. Sometimes the settings get STUCK and changing them gets them back where they should be.
SOURCE: On the LG phone no sound on the alarm... Problem
I had the same problem. I solved it by clicking the lighting (day/night) symbol on the power control widget. I guess the power saving setting will disable the media sounds.
Hope this helps.
No to both of those questions. I have just received the phone.
Well in that case you can try to go to settings-> sounds -> turn off vibrate when ringing and vibrate on touch
and also try settings -> sounds-> volume and change the volume there, activate dial tones, or any other sound options
if no sound comes out at all I suggest you take it back to the store if you have warranty. Sometimes vendors sell broken hardware.
