Need to change wifi passphrase to all numbers or all letters smart tv doesn't recognize letters and numbers
Need to change wifi passphrase from letter and numbers to all letters or all numbers
Posted by Jeanne Blackwood on
Eduard Kellerman
  • 49 Answers
You can auth your tv to use wi-fi without password via mac from wify setup when detected.
disable passphrase from router and connect tv, auth tv and pus back passphrase and it should work, if not, change security type of router to another, WPA/WPA2 where it would let you enter any password you like.
Posted on Mar 05, 2014
How do i change my wi fi on my account so it well work on my tv
You don't change the WiFi, you enter the WiFi details into the television. You can only do this if it is a Smart Television and is internet enabled.
The Wifi has an identifier., mine is Bell597, and a WPA Password which is 8 Letters and Numbers. They are CasE SenSItiVe
Jul 02, 2018 | Computers & Internet
Trying to login to my hulu account on my smart tv. I can't figure out how to capitalize the letters on the hulu tv keyboard. I have capital letters in my password. What do I need to do ?
Hi Glenn,
Depending on the version you have , there is either a key labelled "upper" or there is a button with a "123" on it that cycles modes from letter to numbers to upper case to lower case etc or I have been told there is a button labled "[email protected]#" which apparently does the same thing.
Sep 07, 2017 | Smart Computers & Internet
How to internet to tv
First you must have a smart television that is internet capable. Connect the television to your router with a network cable or by using wifi.
Go to the television settings and put in the Router ID name, mine is Bell596, and the WPA passwork of 8 numbers and letters.
Jul 31, 2017 | Televison & Video
How do I find the MAC address?
Should be a sticker on the tv somewhere that have numerous sets of either letters or numbers in sets of 2 separated by either colons ":" or periods. It may also be under an access panel behind the tv. Last you might try running a set to a network and see if it displays during the setup.
May 01, 2015 | Sharp AQUOS 60" 1080P 120Hz LED Smart HDTV...
How do I get the keyboard to type in youtube search engine (browser) on my Lg smart tv?
As of right now youtube doesn't recognize USB keyboards. They are coming out with update to fix it.
Jul 24, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Vizio tv remote only types numbers not letters
Look on screen keyboard. There are keys to switch from uppercase, lowercase, numbers and special characters.
Mar 26, 2014 | Vizio E601I-A3 60-inch Class Razor LED...
I dont know how to create a wep key i dont know if you use letters or numbers
WiFi Security Best Practices
Use WPA/WPA2 encryption. Avoid using Open or WEP-encrypted WiFi. Use WiFi Protected Access (WPA) or WPA2 with 802.1x authentication if possible. If you use a Pre-Shared Key (PSK) authentication, use a strong passphrase (aka WPA shared key) that is at least eight characters long and is a combination of alphanumeric and special characters.
Sep 15, 2013 | Computers & Internet
Ntel(R) Wireless WiFi Link 4965AGN i want to
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network .
Click Here for more info
Dec 16, 2009 | Computers & Internet
Computers & Internet Logo
121 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
