Whalen Furniture Austen 3-in-1 TV Stand w/Storage Drawer and Tilt-Brown Logo
Mary Muhammad Posted on Feb 26, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
CANN NOT SEEM TO MOUNT THE TV ON THE STAND PROPERLY
We have everything finish except can not figure out out to get the parts that will hold the TV on the stand , can not seem to get it on the stand to mount the TV on it
Dayton Computer
Level 3:
  • Master 1,640 Answers
  • Posted on Feb 27, 2014
Dayton Computer
Master
Level 3:
Answers
1640
Questions
0
Helped
818967
Points
6396
Mounting instructions are in with the setup instruction for the TV or TV Stand. Did a mount come with the stand, or is it a separate add on to the stand? In some cases TV Mounts do come as an option?
  • Gary Moore
    Gary Moore Jan 22, 2015
    im looking for the 2 brackets to mount mine. cant seem to find them anywhere
Blank Screen
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Picture remains for few seconds then screen goes blank, sound remains on
I had this problem on my 42" Philips LCD. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
Screen goes blank after about 10 or 15 minutes. There's still sound coming through. Picture comes back on if you turn the tv off & back on again. Any suggestions? (Sansui HDLCD2200 LCD TV) Thanks.
2answers
Screen goes blank after 2 minutes
Your best bet is to take the back off and look if there are and bulged capacitors on the power supply first, also look for cold solder joints on the 24 volt rail that goes to the HV inverter board. If both seem to be ok then you could have a inverter transformer going bad on the inverter board. Let me know how you do>
Screen goes black tv stays on. Turn off and on and TV's fine.
Whilst watching tv after 10 to 15 min screen goes blank but sound ok ,when u turn tv off then back on u get pitcure for about 10 minthen goes off again
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
[email protected]
2answers
2answers
Panasonic Quintrex 32" 100Hz CRT
Use an uninterrupted power supply, UPS.
Top Whalen Furniture Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Whalen Furniture Televison and Video Expert? Answer questions, earn points and help others
