Question about Microsoft OFFICE 2013 HOME AND BUSINESS 1 PC LICENSE WITH WORD, EXCEL, POWERPOINT, ONENOTE & OUTLOOK; PRODUCT KEY CARD VERSION
I am trying to start my page numbers on 10 instead of 1
I am trying to add page numbers in excel 2013. I want the first page to start on 10 instead of 1.
Posted by Clare on
fire772
    New Friend:
    Problem Solver:
  • 10 Answers
  1. Double-click anywhere on the header or footer to unlock the Design tab in the top menu.
  2. Click the Page Number command. In the menu that appears, select Format Page Numbers
  3. A dialog box will appear. Click the Start at: button. By default, it will start at 1. If desired, you can change the number.
  4. Click OK.
Good Luck :)
Posted on Jun 28, 2014
Formula in excel 2013 for if statement
google-- user manual for excel-- and you will find that information in the 900 pages of the pdf version download
Oct 17, 2017 | Excel Computers & Internet
Why has it stopped working?
Apparently in some cases all you need to do is start Excel/Word/Powerpoint/Outlook as Administrator in order to get permissions to do something on the computer. If you're using Windows 7, right-click the application in the Start Menu and click "Run as administrator". See if this works for you.
In Windows 8, open the Home screen, find the application you're trying to open; right-click it and select "Open as administrator" at the bottom.
. If you are still experiencing the issue I can suggest this program Excel Repair Toolbox
https://www.repairtoolbox.com/excelrepair.html
Mar 29, 2016 | Microsoft Excel 2013 1PC/1User
What are the formulas in grading the grades uisng microsoft excel
Formulas are used to specify calculations based on values in designated cells. Excel supports basic calculations as well as statistical, trigonometric and other specialized functions.
Formulas used in Excel must follow a certain syntax.
  1. All formulas begin with an equals sign (=).
  2. Some formulas use operands such as +,-, *,/ for addition, subtraction, multiplication or division.
    For example, the formula =A1+A2+A3 would add the contents of cells A1, A2 and A3.
  3. Other formulas refer to different functions such as SUM, AVERAGE and others.
    For example, the formula =SUM(A1:A3) would add the contents for the range A1 through A3.
  4. Formulas can be combined with operands.
    For example, the formula =10*SUM(A1:A3) would add the contents cells A1 through A3 and multiply them by 10.
  5. Functions can be nested within each other.
    For example, the formula =SQRT(10*SUM(A1:A3)) would take the square root of ten times the sum of cells A1 through A3. When functions are nested, it is important that the number of left parentheses match the number of right parentheses.
Aug 19, 2011 | Microsoft EXCEL 2004 for Mac
I have a WRT150N router and it will not let me connect to it through the wireless. I have tried resetting the password no luck
Hi Friend,
Please follow the steps in order to resolve the issue:
1.Open the router page
2.Enter the Username and password(default password is admin and leave the username blank)
3.Click Wireless and fill the sections as mentioned
Network Mode-Mixed
Network Name-As per your choice
Radio band-Auto
Wide channel-Auto
Standard channel-Auto
SSID broadcast-Enable and click save settings
4.Click Wireless security and select the Security mode as WEP
Encryption-40/64 bit
Key1-enter 10 digit or 10 letter password(like your 10 digit telephone number)
and click Save settings.
5.Click Advanced Wireless settings and fill the sections as mention
Beacon interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click save settings.
6.Click the link http://homesupport.cisco.com/en-us/wireless/linksys/
7.Enter the model number of the router
8.Click Download tab and enter the verison of your router (turn the router upside down to get the version)
9.Download the firmware file and save it on your desktop.
10. Click Administration on router setup page and then click Firmware upgrade
11.Select the file that you have saved on the desktop and start upgrade.
12.Turn off the router for 30 seconds after upgrade.
13.You can also delete the network name from your computer and add it again.
I hope this will resolve the issue.
Regards
Chiranjeet
May 23, 2010 | Linksys Wireless-N WRT150N Router
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
Sep 08, 2009 | Emerson Microwave Ovens
CAN GET COLUMNS TO ADD UP AND GIVE TOTAL ONLY GET SUBTOTALS
Use the function =sum() to add numbers. To sum, for example, all of column A, enter in the formula bar =sum($A:$A). You can use the subtotal function within the range you are adding and the answer will not count towards the final total.
Mar 14, 2009 | Microsoft Excel for PC
Work day
Hi Chinnu,
For this you will have to install an Add-in called Analysis Tool Pack.
Kindly follow the below instructions:
1. Open Excel Options (Menu-Excel Options)
2. Click on Add-Ins on the side pane of the Excel Options Window
3. Check to see if Analysis ToolPak is in Inactive application add-in list.
4. If is not, proceed to Step 7
5. If it is in the inactive application add in list, Select Excel Add-ins against Manage and click on "Go"
6. In the add-ins menu check Analysis ToolPak and Analysis ToolPak VBA and click OK
7. Use this formula to find the number of work days excluding Saturday & Sunday in a month
=NETWORKDAYS(start_date,end_date, [Holidays])
In your case give the start date as 1st July and end date as 10th July and Holidays as 0 or 1 (doesn't matter). The answer it will return will be 8 days.
Trust the above helped.
Jul 23, 2008 | Microsoft Office Professional 2007 Full...
Reference other worksheet in excel
eg if i want to add to numbers
in sheet 1 i have the value 20 in cell B3
in sheet 2 i have the value 10 in cell B4
thus the formula would be:
=sheet1!B3+sheet2!B4
Mar 13, 2008 | Microsoft Excel for PC
Microsoft OFFICE 2013 HOME AND BUSINESS 1 PC LICENSE WITH WORD, EXCEL, POWERPOINT, ONENOTE & OUTLOOK; PRODUCT KEY CARD VERSION Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
