Question about Pioneer CDJ-800 Turntable
Cant read cd e 8301 - Pioneer CDJ-800 Turntable
2answers
Pioneer CDJ 100 Error E-8301 by every CD
I don't understand your question...please make it clear.
CDJ 400 error masseage
Hi .error code on cdj 400 .e-8301 .have tried the reset by switching on while holding back and USB but still code appears???
Error 8301 comes every for any cd.
8301 error is an error during startup. It should clear if you press the eject button, which could mean something blocking the track or sensor. or call 1-800-872-4159
ERROR 8301 COMES EVERY TIME FOR ANY CD. WHAT SHOULD I DO?
Clean lens and the motor track which moves the lens
Problem e-8301
Although it's in spanish, here you can find a tutorial to disassemble the unit and clean the laser lens.
http://www.taringa.net/posts/hazlo-tu-mismo/9951188/Tutorial-repara-error-e-8301-cdj200-pioneer-dj.html
Usually the error is solved after this.
8301 EROR MECHINCAL NOT WORK
Hii,
This is a player error, try to clean up the laser and compartment of
CDJ. Also, look at ur disc if u play MP3 these must be new, not much scratched
thx
djajay
4helpful
E-8301 error code
e8301 is cd player error at start up. you will have to take the top off and see if laser assembly is stuck from slideing in or out,it should be fully returned to the return switch,it should be close to the spin motor before spinning. also see if disc spins
Error - 8403 on cdj 200 not reed the cd
Can't find Error 8403 in the service manual. Please advise the correct error code and I'll see what I can find out for you.
E-7201 TOC READ ERROR 26: TOC data could not be read.
E-6002 DSP PROGRAM
DOWNLOAD ERROR
62: The program cannot be written in the DSP.
E-8301
PLAYER ERROR
(Startup error)
12: The desired address could not be searched.
15: Address data could not be read.
22: The Focus Servo could not be closed.
91: The pickup could not be returned to the inner track.
E-8302 PLAYER ERROR
(Abnormality in playback)
E-8303
PLAYER ERROR
(Abnormality in writing to the buffer)
99: Abnormality in writing in the buffer
E-8304
MP3 DECODE ERROR
(Abnormality in decoding)
Abnormality in decoding ∗∗
E-8305
DATA FORMAT ERROR
(Inappropriate data format)
A data format other than MP3 was used. ∗∗
E-9101 MECHANICAL TIME OUT 90: Abnormality in the disc-loading mechanism (TIMEOUT)
Pioneer CDJ-800 Turntable Logo
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
