Blakeslee F-30-CA 30 Quart Planetary Mixer Floor Model Logo
A
Anonymous Posted on Feb 25, 2014
Need manual to ID the part I am missig and to verify model.
How do I get a manual
Hi Jeff,
I was able to locate the spec sheet for this product:
http://mvpgroupcorp.com/details.php?cat=7&id=119
You may have to contact the manufacturer to explain which parts you want to order. I was only able to find service information for their JetTech product line.
How do you use the bread dough beaters?
Retrevo has link to the Instruction manual for the MixMaster 2369 here: http://www.retrevo.com/support/Sunbeam-2369-manual/id/952ci068/t/2/ . You will need to enter a code to download the file. You will also need Adobe Reader or a similar program to read the file.
I hope this helps.
14helpful
Is there an exploded assembly diagram I can reference
Hi LONGLEY632. It sounds like you’re in the need of your mixer’s parts list. It provides ‘reasonable’ exploded views of the various components of your mixer. Enough so that you can disassemble, identify parts and reassemble your mixer.
You can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> then enter the visitor type “Consumer” and the 6 character model number, in your case use KSM90P, in the Model Number box. Select one the files listed for your model that appears under Parts List (16): KSM90PSWH0.pdf (354.08 KB) and save that file to your PC. Check to verify this matches your mixer model.
Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
1helpful
Replacing the brush
Hi DENAULTR, this is a repeat of my previous answer to your problem. It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this manual), and select the first file KSM50P.pdf (438.31 KB) listed under Parts List (4) and then check to verify this matches your mixer model. Turn to pages 6 & 7, titled ?Motor And Control Parts?, which provides an exploded view for the disassembly and reassembly of your mixer?s electrical components, along with all the part names and numbers. Locate Illus No 47, Brush holder assembly that includes Illus. Nos. #28, 32, 33, 34, & 46, and Illus. No. 29, Brush & Spring assembly respectively. Make sure you orient each bruch correctly following the illustration here: The Parts List diagrams along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA If this solution has been helpful to you, please rate it, thanks! -hslincoln
1helpful
No problem just need a manual for all the parts of a K5ss mixer
Hi AUER24, you can easily download both the Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> and enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
This particular manual provides both domestic US and International Part numbers, which you will want to use, based upon your 220 volts rating that tells me you have an international model.
For future reference, here are five potential USA vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com (for grease). You should search for ‘food grade grease’ online (although I’ve seen automotive bearing grease used too – your call). Prices can vary widely between vendors, so do some comparison shopping.
Also, here are some links to three excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble, determine what’s wrong, order the correct parts and reassemble your mixer.
Good luck. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
3helpful
I need the manual for my K5SS mixer my
Hi WWW_SOCRAFTI, you can easily download both the Owner’s Manual and Parts List manual for your K5SS mixer online from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P (Your K5SS mixer falls within this model range), and then select this file: KSM50PPWH0.pdf (5156.65 KB) from the Owners Manuals (9) list and this file: KSM50P.pdf (438.31 KB) listed under Parts List (4). Check to verify they match your mixer model. You can save them to your PC hard drive, and then you can print a hard copy if you wish, or just refer to it when you need to use it.
The reason I suggest downloading the Parts List manual is that should you decide to try and troubleshoot and fix your KA mixer, this manual will be invaluable in the disassembly and reassembly of your mixer along with listing all the part names and numbers. Having the correct part names and numbers is critical when reordering replacement parts when your mixer eventually will stop working.
Good Luck with your mixer, I hope this helps. Howard, Burke, VA
How do I access the gear box?
Hi RJ0804, it’s quite easy to disassembling your mixer (OK, it may require a little bit of effort). Here are links to three excellent websites that detail with pictures the disassembly, re-greasing and reassembly of a KA Mixer.
This will allow you to remove the top housing of the bottom of the mixer and provide you access to the gears within the head of the mixer.
Once you get that done, you will want to have the Part List manual around for the rest of the disassembly. If you're lacking one, you can download it from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case KSM150P and select the next to last file KSM150PSWH0.pdf (773.44 KB) (it’s the white model that’s all…) listed under Parts List (61). (Verify that it matches your mixer model, though).
To disassemble your mixer you will need the following tools: a regular & Phillips screwdrivers, snap-ring pliers, a small drift pin punch and a small hammer. By using the exploded views in the Part List manual, you should be able to disassemble, inspect, identify, replace and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
WERE DO YIU GET TECH MANUAL
Hi, EMININES. KA does not provide a tech manual, per se. They do offer their mixer’s Owner’s Manual and Parts Manuals on line, and with the help of some very good web site links, you should be able to service your KA mixer. You can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use KSM50P, and select the first file listed under Parts List (4) and then check to verify the illustrations match your mixer.
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Hello, I have sunbeam mixer model #2360 and had one large and one small turntable. I lost the large turntable and am unable to locate a site to purchase another one. Can you please help? Thanks, so much!
Sunbeam 2386 Sunbeam 2386 MixMaster Series 275 Watts Stand Mixer. Overall User Rating. 3.0. out of 5 ... 2386 Reviews & Articles. Sunbeam - Small Appliance Parts ... retrevo.com/s/Sunbeam-2386-review-manual/id/952ci071/t/1-2
Good luck_Ned_
Top Blakeslee Food Mixers Experts
ADMIN Eric
ADMIN Eric
john h
ADMIN Andrew
ADMIN Andrew
Are you a Blakeslee Food Mixer Expert? Answer questions, earn points and help others
