Microsoft Xbox 360 Wireless Controller Logo
Question about Microsoft Xbox 360 Wireless Controller
How to stop a xbox 360 controller from itself
When i play GTA 4 or go to my friends list it moves itself like when i check my friends list it goes all the way down itself how do i fix this problem.
Posted by Emmanuel Cruz on
RockemSockem
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Controller thumb sticks may be worn/dirty and are providing unwanted input. Search you tube for Controller Cleaning instructions - an easy fix, I've done many times.
Posted on Jan 16, 2015
5 Related Answers
Anonymous
SOURCE: i need help xbox 360 black screen
OK, I think I can slove your problem.
There is a slide setting thing on your av cord that gives you the option of using TV or HDTV (look near the end of the cord that slides into the XBOX 360), You will see two choices for settings on the cord "TV" or "HDTV".
Just make sure that you have it on the correct setting. I had the smae problem. My XBOX 360 is not hooked up to HDTV, so for me it should stay on TV. But somehow when I took out the cord I accidently slide it to HDTV.
I simply slide it back to the "TV" Setting and in about 30 seconds it worked perfectly.
I hope this helps you.
Posted on Dec 29, 2008
Anonymous
SOURCE: gta IV won't work on my xbox 360
it has to do with your tv if you have a 50 pal tv u will need a 60 pal because the grafics are good
Posted on Jan 16, 2009
Anonymous
SOURCE: xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Posted on Feb 07, 2009
Anonymous
  • 3 Answers
SOURCE: xbox 360 sync problem - controllers will not connect
maybe the only way is take it a part and see if the sync button is not broken some how. therefore i advise you to buy a new controller maybe even a used 1 if you dont want to spend more than $20.
Posted on Mar 31, 2009
Anonymous
  • 174 Answers
SOURCE: Xbox 360 plays for a few minutes and then the screen goes black with no sound or picture.
your graphics processor IC chip needs its solder joints reflowing, and the heatsink re securing.
This will solve the problem.
Regards
FixMyConsole
Posted on May 20, 2009
4helpful
I downloaded ballad of *** tony but i cant figer out how to get to campain
It should prompt you upon first start up if you want to play, simple question.. Have you got the original GTA 4? TBoGT is a DLC Expansion pack.
If you have, follow these steps: 1. Load up GTA 4 2. Press Start > Scroll across to "Game" 3. New 4. TBoGT
It sounds as if there is a piece moving around inside my xbox.Gta:4 plays fine but MW2 doesnt play at all
If there's something in your XBox moving around, you could have broken something, or someone could have put something in it that shouldn't be in it. If you don't mind to void your warranty, open it up and see what you can find that might be out of the ordinary. You might also want to dust the system out, so that its life is prolonged.
Xbox 360 won't read a certain game It reads all games fine except Halo 3, tried 2 copies, tried them in my friends xbox 360 and they both work, GTA 4 PGR 2 MotoGP saints row, works just not the game i...
If you have the original X box CD's it will work fine expect when you have issues with region code.PAL NTSC are the two format a game can work with.so if you have NTSC formated game TRY a PAL version.it may work.
else clean your lens and try inserting a new CD of that GAME.
Ring around disc
i had this problem... make sure the xbox dosent move while you are playing it if it does than make it stop somehow
2answers
Screen freezes
HI...
Contact Microsoft tech support
http://support.xbox.com/support/en/us/xbox360/hardware/default.aspx
There's phone number there too if you dont find your problem listed
2answers
GTA4 not responding to controller
Bring the game back to where ever you may have made the purchase, there reason could be a possible faulty disk, the main thing to ask yourself is....Are you able to play another game? if so, does this issue occur?
If yes, then there is a HIGH change it is your remote, however...if not, then it is the disk, for GTA4, Let me know how it goes,
Thanks,
Justin.
Please Rate Me
1helpful
Why cant i play any xbox games on my xbox 360
There could be a few reasons:
1: The game is not able to be played on the xbox 360. Only certain games can be played on the xbox 360. Go to http://support.xbox.com/support/en/us/xbox360/askxbox.aspx and type in "original xbox games". It should pop up with a list of games that can be played on the xbox 360.
2: Your family settings do not allow you to play original xbox games. Go to the control panel and look at the settings.
2helpful
Gta IV won't work on my xbox 360
Gta 4 xbox 360
You have corrupted data on your disc. You are going to need to get another copy of GTA:4, or trade it in/return it for another one.
Hope this Helped.
Top Microsoft Video Game Consoles & Games Experts
David Shaub
Narseman
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
