Question about Ricoh Aficio IS420 Flatbed Scanner
How to scan in text formate in ricoh2030
I bought a ricoh2030 printer & Scanner but i no know, how to scan in text formate from this scanner pls tell me how to scan in text formate in ricoh 2030
Posted by ms_atul1991 on
Anonymous
  • 256 Answers
You need an OCR (Optical Character Recognition) program such as Textbridge or Omnipage ect. The program should use your scanner to scan and then read the page(s) and save as text.
Posted on Jun 11, 2009
Canon 272 scanner software
You need to install the software then connect the scanner & open the software. Put the paper in scanner & then click scan option in software for scanning. Select before scanning your choice. Jpeg /PDF format u want.
Aug 09, 2012 | Office Equipment & Supplies
How do I scan a document?
see the printer is connected to the computer, printer is powered on, & the document u want to scan is layed upside down in scanner. then open "paint" software & go to "from scanner or camera". follow the instructions on screen & finally save the image in required format which u will see in save window bottom side (drop down menu).
Sep 03, 2011 | Brother DCP-135C Flatbed Digital MFC...
Pls help me w/ my scanner. i can't use it bec. i don't have a software. so how can i fix this prob. thanks
Does your printer / scanner is installed with proper drivers ?
?f so, please let me know what operation system you are using on your computer, so I can guide you how to scan without additional software.
May 10, 2011 | Office Equipment & Supplies
I cannot scan documents and edit them. I can only get my text as a picture. I have a MacBook Pro
Scanner in general do not recognize text; once a document is scanned, an OCR (Optical Recognition Software) must be used to recognize characters.
Some OCR software are bundled with scanners, and you aquire them from different download sites; I can help you if you are interested.
pls. vote for better service. Thanks
Nov 12, 2010 | Canon PIXMA MP600 all-In-One InkJet...
How to scan a document in pdf format from hp psc 1315
  1. Position the first page of your document on the flatbed scanner and close the lid.
  2. Step 2 In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
  3. Step 3 In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
  4. Step 4 Click "Scan."
  5. Step 5 When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
  6. Step 6 Repeat the above steps as necessary to scan a multi-page document.
May 30, 2010 | HP PSC 1315 All-in-One Printer
Canon mx320 does not scan
make sure that scan driver is completely installed in your computer.
To scan a documents in jpeg format, use the scanner icon in the control panel of your system. Insert your document in scanner bed then double click the scanners & cameras icon in the Control Panel.
To scan a documents and save in pdf format. just press the Scan button in the printer and save the documents in your computer once the scan window appear.
Oct 20, 2009 | Canon PIXMA MX310 All-In-One Printer
I just bought a new lexmark copier, scanner, fax,
This should give you a good explanation of what ocr is.
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_1268319518_0_en,00.html
Jul 07, 2009 | Lexmark X3550 All-In-One Printer
Scanner reserved for pc scan
Get the latest driver´s for windows vista or get rid of windows vista it´s not a good OS extremely slow and very messy a lot of problems a resources consumption.
Hope it helps
Jun 25, 2009 | HP LaserJet 3030 All-In-One Printer
Scanning
As with most scanners, place the document in the scanner for scanning. Open the software that you wish to use. Select "File" from the menu and then "Import". Your scanner interface listing should appear. Click on the device to begin your import from your scanner. Your scanner should scan the document and it will appear in your application. Be advised, Scanners scan in a Graphic format. To edit in a wordprocessor you will need some kind of OCR (Optical Character Recognition) Software to convert the graphics into a wordable form for editing.
Jun 11, 2009 | Canon Pixma MP480 All-In-One InkJet...
Editing a scanned document
Hi, You can try use an OCR program. Sometimes it is included/bundled in the software/drivers/application CD that came with your scanner. You can also google for freeware versions. OCR (Optical Character Recognition) will recognize the text from the scanned document, you can copy/paste and thereafter edit. Hope this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | HP PSC 2355 All-In-One InkJet Printer
Ricoh Aficio IS420 Flatbed Scanner Logo
195 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
