Master:
Nikon Master
Re: What does err with flashing film picture mean
It means either your film has reached the end, the film is jammed and cannot advance or the film is improperly loaded. The film leader may have slipped from the sprocket or broken,
If the LCD panel shows "E" then the film isn't loaded properly. If the LCD panel shows "ERR" and "E" blinking, then the film is not correctly advanced. If the LCD panel shows a blinking "E" when the exposure meter is turned on, then film remains in the camera after it has been rewound. In all cases, reload film.
If it's not one of those cases, or if the problem persists, please reply to this post giving further details.
The film is not inserted correctly. pull film leader out until it just reaches the red line on the take up spool, then close the bacl. "ERR" should be gone
It could be that your camera doesn't know it's rewound the film already. With the camera turned on, push and hold BOTH manual rewind buttons simultaneously - one near the release button ( +/- ) and the other toward the front of the camera at the lens release button. Try the release button again.
Is the film loaded correctly? Have you tried reloading it? Also is it flashing DX too? That would mean the film speed is not DX coded so you need to set the film speed manually.
First check the batteries. Are they fully charged? If you still have the same problem, try this:
Is the film (that which did not rewind fully) still in the camera? If so, open the film chamber door once in a dark room and close it again. Try to rewind the film again. This could possibly be the result of the film getting stuck somewhere, preventing the camera from rewinding it.
In my case, I borrowed a camera and when I got it back, err 05 appears.
I've located a bit of old orange juice which sticked one of the sensors
- you can see the sensors when flash is popped out.
You might want to check the position of the aperture ring on the lens. If it is not set at the highest number, ( IE smallest aperture, f22,f32 ), then the camera will display that error message
