Question about Nortel Norstar M7310 Telephone
Change address / Option 3 on phone
We need to change our address location with option 3; how is that done
My emails on Galaxy 3 is automatically deleted in 3 days. How t change it. I want emails to stay for 30 to 45 days
First delete the email account, after that is going to show you a new window of set uo email , after that go head and put your email address and password and theres an option down that says // manual set up.. go head and press that option , now theres 3 options click the one that says POP and just follow the steps and should be done and fine to go .
OR
The setting is under More Settings, then under Incoming Settings. On the bottom it says 'delete email from server' and mark 'never'. :)
Nov 19, 2014 | Samsung Galaxy Cell Phones
Ive got a password and a primilary E mail address but ive put the rong phone number in how do i reset it
go to Settings.
then Accounts.
Click Change password recovery options in the 'Change account settings' section.
Click Add a recovery email address/a mobile phone number/security question if you don't have a recovery option already, or click Edit next to your current recovery option to change/remove it.
Click Save to make your changes.
Close the Google Account window using your browser's Close
Aug 15, 2014 | Google Gmail
Change of shipping address
Hi you can change your shipping address in USPS(US postal service) website https://www.usps.com/.In the site there is a option called Manage your mail => change of address. you can follow the steps and get it done.
Oct 02, 2013 | Computers & Internet
Changeing Password on Router
First, you'll need to reset the router, this is typically done via a tiny reset button located on the back of the router (you'll need a paper clip to press it). After that, changing the password requires you to know how to access the router options. This is different from brand to brand, but typically by simply going onto Google and searching for your modem's address (might be an IP address or actual address, like linksusrouter). Then just go into the settings, find the "change password option" and viola.
Oct 09, 2012 | Westell Versalink 327w Wireless Modem...
IP address change needed on a AlphaServer DS10
First, identify the NIC you wish to change; use:
$ MC LANCP <ret>
> SHOW DEVICE
Next, use the menu driven utility "TCPIP$CONFIG", to set your desired IP address etc:
$ @TCPIP$CONFIG <ret>
Option 1 - core environment
Option 2 - Interfaces (then select your NIC or the IP Addr to change)
Option 2 - add/change a Primary address on *** (where *** is your NIC).
May 15, 2012 | Compaq AlphaServer DS10
Hi there, First of all I'm completely new to GPS and a friend gave me her Garmin 255W, I've managed to fine a USB cable which charged this unit which is a plus but when I go to checking out different...
You can clear all the user data by holding your finger on the bottom right corner of the screen when turning on the satnav. Once the data is deleted you can set your home location by pressing WHERE TO and then GO HOME. As you won't have a home destination set it will give you 3 options
  1. Enter your address
  2. Use current address
  3. Choose from a list of recently found locations.
If you're at home, choosing option 2 is probably the easiest. You'll need to be outside so the satnav can access satellites. If you're not at home you can use option 1 or 3.
You can find the user manual for this satnav at http://static.garmincdn.com/pumac/2675_OwnersManual.pdf
Apr 05, 2011 | Garmin nuvi 255W GPS Receiver
I have a semobi x2 mobile phone and want to access internet
Here are a few things you need to know.
one, the default manufacture password is 1234 or 1122 or 0000. You may need to use it when you reset the phone.
Two, if it is a TV mobile, then you need to set the country area as “singapore” or “Indonessia”
and then search all the channels, you will get the best reception.
Three, to save the battery power.
1. turn off the Bluetooth function.
2. If you only use one Sim card, then turn off the second one. Just go to “settings” and then choose “Dual sim settings” and then select which one you want to turn off. (if you turn off one sim card and find out your current sim card can not get vodafone network signal, then you must turn off the wrong one, please change over)
Four, you may need to use WAP and PXT later. So, here are some instructions which may help.
1. go to the main screen, choose” Service”, then choose” data account”, then choose” GPRS”
2. Choose the first one.. Then, the screen will change to Edit manual.
3. now, choose Edit the “account name”. then change the data account to “Vodafone”. then choose the “option button” and you will see 1. done. 2. input method. then. choose” Done”
4. After you have done this, the screen will go back to the “Edit manual”
5. Now, you need edit the “APN”. just change the “APN” to “live.vodafone.com”. choose “option” and “done”
6. After done this, the screen will go back to the “Edit” screen again. Now, choose” Done” which is on you down right hand side. And it will ask for “save”, Choose “save”
7.Go back to the “wap” and then Choose” settings”
8. Choose” Edit profile”
9. now it will show 1. SIM1. 2. SIM2. Choose sim 1.
10. Choose the first one, After you click the first one, you will be able to see” 1. active profile” “2. edit profile”
11. Now choose “edit profile”
12. Now, choose 1. “Rename profile”, click “edit”. Change it to “vodafone”, then choose” done”
13. Then, edit the 2′home page” change it to :”http://live.vodafone.com” choose “option” “done” ( if everything you set up is in “Capital” then, you need put HTTP://LIVE.VODAFONE.COM. this is very important)
14. Then .choose “3 data account”. choose” GPRS”, choose the first one” Vodafone”.
15. Then, it will go back to the “edit profile”
16. then. choose “4 connection type” HTTP, then choose” OK”. Now you will be able to see “the proxy address”, then change it to”172.030.038.003′ and change the “proxy port” to “8080′. then choose” OK”
17. It will go back to the “edit profile”. then choose” Done” and it will ask to “save” just choose” yes”. Then choose” Avtive profile”
18. The same process to do on SIM 2 if you want to use the second sim card to surf internet. Now we just completed the vodafone live and do the PXT settings.
19. go back to main menu and choose “messages”. then “mms” then “message settings” then “server profile”
20. choose “sim 1′ and then the first profile then “edit profile”.
21. change name to “PXT vodafone” and “done”.
22. change “homepage” to “http://pxt.vodafone.net.nz/pxtsend”. (or HTTP://PXT.VODAFONE.NET.NZ/PXTSEND)
23. go to “connection type” and click “http”
24. change IP ADDRESS to “172.030.038.003′ and port to “8080′ then “done” and save all the changes.then activate profiles
25. Now Sim 1 pxt should be working.If you want SIM 2 to use PXT service, please change the settings following by the procesures again.
Dec 06, 2009 | Cell Phones
How do i change my the home address and who my tomtom one belongs to?
Change preferences (5th option on first page)--change home address(3 option on 2nd page)--address(3rd option on first page)--then just find your address
Sep 24, 2009 | Tomtom ONE 3rd Edition GPS
Changing home address
  • Tap the screen to bring up the menu
  • Tap the 'Change preferences' icon
  • Tap the arrow to the right to the 'Change home location' icon (looks like a house with a spanner)
  • Choose the best option to identify your address (postcode, address, recent destination, etc)
Dec 27, 2008 | Tomtom One XL GPS Receiver
Nortel Norstar M7310 Telephone Logo
14 people viewed this question
Top Nortel Computers & Internet Experts
Joel Rodriguez
Joel Rodriguez
MrFixitSTTL
Vebble
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
