I plugged the charger in & the red battery light indicator came on and then the unit turned off, I tried charging it again but then the green light battery indicator came on then it went off all together & now nothing works on it, I've tried the mute button reset but nothing, thanks
SOURCE: using the soundlink wireless music
Simply plug the small USB key into your computer, turn on the SoundLink system and select your music--iTunes, Pandora®, whatever you like. That's it. No networks to configure, no cables to run. And you can control your music using the handy remote.
Remove the battery in the machine and put back. Also, remove the battery in the remote and insert a good battery.
To turn off youe aux simply press the aux botton on your phone i am sure it will work.
Thanks for contacting Fixya
SOURCE: I bought a Bose V35
I bought Bose v35 every thing is good, But my iPhone option does not show video, I have audio.
SOURCE: I have a Bose Wave II radio. Never a problem
in your boss amplifire system hardware problem in u try to mute and volume button please check aux port also if found no output sound then go boss service station there are some hardware problem
SOURCE: Problem getting my bose soundlink to play blue tooth audio from my laptop.
Hi Sirtuan.
Go to the system panel, there choose "sound" . a list with all available sound devices appear. search for your bose soundlink and make it your "standard device".
had the same prob. with my BT headset and this works for me.
if your bose get disconnected the sound should automatically switch to pc speakers.
Regards
Gue.
