Pentax K1000 35mm SLR Camera Logo
Question about Pentax K1000 35mm SLR Camera
Exposure needle not working
Pentax K1000 camera exposure needle stopped working recently. Have replaced battery but still dead, What should I be checking next?
Thanks
Thor
[email protected]
Anonymous
    Scholar:
  • 185 Answers
Clean the battery cover and contact with a pencil eraser making sure the cap threads are also clean.
this is a fairly expensive repair if the meter or circuit board needs replacing ( no new parts are available ).
if the meter still does not work, and the K1000 is in good working order buy a inexpensive hand held light meter.
Posted on Jun 11, 2009
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Long exposure? how dp you acoomplish this using the pentax k-1000
You will need an external shutter release that locks. Connect the shutter release, then on the camera set the shutter dial to B (bulb). With the shutter release cable fire the camera and lock the plunger, or hold it down. Using a shutter release cable you are less likely to cause camera shake. Of course have the camera on a tripod or something steady.
1helpful
The light meter is not working on my Pentax K1000
there are three different possibilities. remove three screws, take off bottom cover. remove three screws of battery holder, lift to see if the battery wire has corroded or broken off. solve by extending wire and resoldering. the next involves removing the top cover to see if the meter coil is dead,if this is the case it needs to be replaced, or there is a broken lead somewhere. usually it is cause no. 1.
All images on my slr digital camera are very light almost non existent picture
have you checked your exposure and aperture? To high an exposure or too large and aperature can affect the picture quality. I have a model like this I think. When you look in the view finder, there is a meter with a meter that, if the batteries are good, should move up when there is too much light, and down when there's not enough. If you can get that meter to the middle, you'll be OK. The closer to the middle that needle is, the better the quality. :)
3helpful
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
2helpful
PENTAX K1000 CAMERA EXPOSURE METER IS NOT WORKING
Clean the battery cap and contacts with a pencil eraser including the cap threads.
there are no new parts available for this model Pentax, so a good used part repair could be expensive.
An inexpensive hand held light meter might be the way to go if the cleaning did not work, and the camera is otherwise working good.
1helpful
2answers
Missing battery cap
I lost the battery cap of my K1000 on vacation...I replaced the battery and taped it snugly in place with a bandaid. It hasn't budged in a year! Just find a good strong tape and tape over the battery.
Pentax SF10 Camera -- double exposure
If you press the film release button like you are going to rewind exposed film you may be able to activate the film advance lever to cock the camera so you can take another picture, and the film should stay on the first exposure allowing you to re - expose it. I would underexpose each image 1 F stop because.you are exposing the same film twice. Double exposures are always an iffy proposition and anything can happen. After the second exposure cocking the film advance should allow the film to advance once again. You might test this on the final pictures on a roll in case the camera won't start advancing the film after you try it. This way you won't blow a whole roll worth of pictures testing it.
Light meter
Yes, the Pentax ME Super has a built-in light meter. It is used by the ME Super in order to determine the correct exposure settings when the camera is used in the "A" (Autoexposure) & "AV" (Aperture-priority) exposure modes.
I don't mean to insult you, but have you tried new batteries?
Sometimes the meter fails when the batteries don't have enough juice.
Take care & Happy Imaging!
Glen
Film advance lever stuck
The shutter parts are most likely broken. That is usually the tell-tale sign of a broken camera, not advancing. Repairs for film cameras are very expensive and if parts are needed, it may be impossible for a 20+ year old camera. My suggestion is to find a replacement film camera system. Your Ricoh lenses will fit on a Pentax camera, but not work in Auto Mode. Prices of used Pentax cameras with built in motor drives are around $100. Check on line cameras stores. They have lots of use cameras/lense. A lens to use on that is another $75 or so. Only Nikon and Canon make new film cameras anymore. If you want an indestructable K-mount, find a Pentax K1000. Many lenses are available but no motor drive nor auto exposure on that model.
Top Pentax Photography Experts
Steve
Are you a Pentax Photography Expert? Answer questions, earn points and help others
