Question about Mitsubishi WS-65869 65" Rear Projection Television
Mitsubishi 65 inch Diamond rear projection
Hi, My electric went out a couple of days ago while the tv was on. When the electric came back on I can't turn the tv on. The green power light just keeps blinking. I have tried unplugging it overnight but still keeps blinking. Thank You, Joe
Posted by geusepinna on
Anonymous
    Problem Solver:
  • 10 Answers
Sounds like your control unit has going down. its the big silver box in the rear to the left of the set.
Posted on Oct 28, 2007
Mitsubishi 65 inch rear projector TV with remote. Model WS65807. HD ready, but not HD. Has failed circuit board, part number 930B866001. This board regulates audio and video. Part no longer available...
Short answer: No.
The board and install will cost you more than an LCD/LED flat screen TV.
Sorry for the bad news, but you will save space and electricity with the new TV.
Next problem: Trashing the projection TV.
Oct 25, 2017 | Mitsubishi WS-65807 65" Rear Projection...
Intermitent Shot Off
Please check the sleep timer is off..
Sep 23, 2007 | Mitsubishi Diamond WD-65831 65" Projection...
My Mitsubishi Diamond 55 inch tv just went black and then the red power light blinked, when I went to manually turn it back on, it did not come on at all...is it able to be reset or fixed?
lindapuzino0,
I have relatively bad news for you. Your model has known issues witht the DM board and power supply board. Mitsubishi has no spares and their repair incentive has ended. I have a tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer which explains the problem and where to get a kit which could possibly repair your unit if you think you have the technical skills.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Jan 12, 2011 | Mitsubishi WS-65809 65" Rear Projection...
TV Turns Off On Its Own
Standby light flashing is error sign and shows tv got problem some where in its circuit boards.
You will notice 3 seconds long pause between red standby light flashing so count pause to pause and post how many times it flashing to diagnose problem of tv.
Thanks.
Jul 01, 2010 | Sony KP-65WS500 65" Rear Projection...
I HAVE A 65 INCH MITSUBISHI TV WD-62531, WAS WATCHING TV, AND ALL OF SUDDEN THERE IS A BLACK FILM ON THE BOTTOM OF THE SCREEN. CAN ANYONE HELP ME OUT WITH THE PROBLEM, PLEASE EMAIL [email protected]
Have a Mitsubishi 65 rear projection menu keeps fading on and off, any ideas of the problem. Bulb just replaced 2 months ago, no problems with bulb. Also a DVD works fine, but tv picture will not come on.
Dec 24, 2009 | Mitsubishi WD-62531 Projection Television
HDTV CABLE NOT HOOKED UP/WORKING
COMP 1 and 2 are for 480i/p sources. Hook it to the 1080i capable on the back. Also make sure the HD DVR is outputting 1080i not 720p. The Mits can not disply 720p and will show a scrambled screen if you try to.
Jan 31, 2009 | Mitsubishi WS-65809 65" Rear Projection...
The television remote controll is broke.
You can get Original Remote for WS-65815 from Mitsubishi Parts.
Nov 24, 2008 | Televison & Video
Mitsubishi 65 inch rear projection diamond
its the circut board that leads into tv from power cord , i had bought mitsubishi65819 black diamond gray 65inch for $54 ,is under the warranty the board cost $350 , labor $200 but this depends on where u live ,either way it was a steal for me ,but yea i had same problem when u turn tv on it shuts down like not even 2seconds i had tech come out and he had to take the board to get it repaired ,its not available he said but its repairable , was a sears tech so sears can repair it
Oct 29, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65869 65" Rear Projection Television Questions
Mitsubishi WS-65869 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
