GE gsl25jfre Refrigirator working fine until compressor stop and does not cool. I have to unplug the power cord for about 10-15 seconds then plug it to the power. Then the compressor will work. I do this everyday. Please help
This is a common problem for your GSL25JFR . It is very likely a defective=> WR55X10942 Main Control Board Usally when this happens the start relay, overload and run capacitor are also changed when replacing the WR55X10942 Main Control Board. I'm here should you want my assistance,Thanks, John Tripp Appliance 911
Contact Me Here
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
SOURCE: Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
SOURCE: Sears Kenmore 53652300, doesn't cool
This usually indicates that the compressor is working too hard and drawing too much current. The click that you hear is a safety shut-off. Possible causes of this are numerous and usually require having a professional come in to fix the issue, it can range anywhere from a faulty compressor to a bad start relay.
There is in most cases a temporary fix, it is called a hard start relay/capacitor. It is usually available from an appliance parts retailer for around $15 to $20. Installation instructions are included, just be sure to unplug your refrigerator first and make sure that someone following you can repair from where you left off. This relay assembly can normally get you up and running but it should not be used as a permanent fix. This will not correct for a refrigerant leak in the system.
Check your refrigerator owners manual before making any repairs or modifications to your refrigerator, there may be an extended warranty on the sealed system and compressor.
SOURCE: not cooling, compressor kicks in for 3 seconds then back out
No the PTC relay on the compressor is bad. Need to replace it.
First be sure to unplug frig. Remove the cardboard cover that covers
most backs of the frig units. Remove the plastic cover that is on the
side of compressor. It is held on with a metal clip. Now you should be
able to see the relay pry the relay straight off. note the wiring and
position of relay. Only three prongs on compressor. Go to a parts house
for appliance's and with your make and model number should be able to
get a new one. Let me know if you need any more help. ken
SOURCE: Maytag refrigerator isn't cooling
Hi ****, Based on the discription you've provided it sounds like either a faulty start relay or the compressor is seized. If you have a multi- meter you can check the compressor to see if the windings are ok. Unplug the fridge. Remove the panel at the back down at the bottom. This should gain you access to the compressor. On the side of the comp. will be the start relay/overload assembly. Pull off the relay & overload and you'll see 3 pins in the form of a triangle. With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin. You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms. On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good ! If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit. This will start it if it's not seized also known as a "locked rotor".. You can find them at most brick & mortar appliance parts locations or on-line vendors. The package contains info on how to connect it. If that doesn't yield any results moving forward, let me know we'll go from there. **I suggest you phone Whirlpool customer support first though ( they own Maytag ) as they recently had a massive recall regarding the starting device of many compressor's and you may find your's to be included therefore have it repaired at no cost.** they will know by your model and serial number or if that isn't clear the number on the compressor. Good Luck Thanks for visiting "fixya", please take a second to rate my solution and leave a comment/testimony to it's helpfulness. macmarkus :)
