Question about Fuji FinePix F650 Digital Camera
Distorted viewer screen
The digital scrren has lines through it and the picture taking has become distorted...there is a small exclamation point with a hand beside it on the viewer...I'm guessing this is some sort of error message?
[email protected]
Posted by Kyle Butterfras on
  • 1 more comment
  • riverslick Aug 05, 2008
    I use the Pentax Optio W30 often and have much enjoyed the results. However a couple of months ago several vertical white lines appeared on the left side of the viewfinder. The camera was still usable. But now the viewfinder is completely obscured, and does not show images or 'mode selections,' so I have to leave it in 'auto pic' and guess at the picture I want to take. The resulting pictures are clear, but usually NOT the image I wanted. In short, the camera is essentially useless, except for general landscapes. What can be done to fix the problem? I have not yet contacted Pentax or anyone about the problem. Thanks, Ed in TN
  • jramsay66 Aug 21, 2008
    A couple of days ago my Optio W30 started to display vertical white lines down the left hand side of the LCD view screen. Irritating, but not disastrous (yet), since only about 1 cm of the screen is affected. I have no idea how to fix this...
  • Anonymous Jan 18, 2009
    same
Anonymous
    Problem Solver:
  • 10 Answers
Depending of brand and model. A lot of digital camera are having same problem and solution is replace the sensor.
Every camera maker is ready to replace for free the sensor, plase contact the camera service then follow operator instruction.
Every ready to help the people
Posted on Jan 14, 2008
Orange light comes up isn't letting me take pictures black screen
Could be a problem with the LCD viewer screen, or, if not, could be the CCD image sensor go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Kodak service.
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
Hope this helps
Sep 19, 2011 | Kodak EasyShare Z710 Digital Camera
My pictures have lines across the screen in the viewer and are also sometime dark. this happened suddenly. The message boards point to a shutter problem with this camera. Is it fixable, worth fixing, a...
Sound like a malfunctioning CCD-image sensor. Rare, but possible problem with your LCD screenviewer... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Samsung service.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Sep 07, 2011 | Fuji FinePix F470 Digital Camera
While i switch on the camera it shows a good display but after having one and two snaps the screen become dim and later on just the lining appears
Could be a problem with the LCD screen viewer or CCD sensor go to bad. This condition is the same when your pics are showed in the pc ? Are you check ISO settigns? If yes, and the problem continue, first... could be a problem with the LCD viewer screen, or, second choice could be a problem with the CCD sensor or go to bad; in both cases this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check THIS LINK for additional details in this previous solutions for an Defective CCD (Charge Coupled Device) and next contact your Canon service.
If your camera have some "anti-vibration" setup, check if this is activated, or its possible that this system is go to bad or need to be recalibrated.
Hope this helps
Aug 24, 2011 | Kodak EASYSHARE Z1285 Digital Camera
Hello, we need help in our camera, my friend touched something and the screen becomes black and for several checking it goes back, and just now it becomes black again. what we are going to do about it?
Try to take a picture and see if it takes - check the picture on a computer. If it's ok, then you could have a problem with the viewer, not the camera.
Dec 09, 2010 | Canon PowerShot A470 Digital Camera
When I try to take a picture the scrren reads
the memory card should have a small switch on the upper left side it slides from lock to unlock if this doesnt work Look in the card slot - there may be a small bit sticking out over where the card's locking switch would fit when the card's inserted
Oct 24, 2009 | Casio EXILIM Card EX-S770 Digital Camera
My screen is not working
The 35mm Canon DSLR cameras don't have that option like lower end point and shoots. The image must be captured prior to viewing.
Sep 13, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Distorted image
Sounds like you may have a faulty CCD Sensor or the wiring came loose. My Camera did the samethimg. Email [email protected] and explain to them the problem.
I
Aug 06, 2008 | Canon PowerShot A75 Digital Camera
Focus is completely out of whack
i'd probably say try a repair place. It's a problem with retractable lenses.. better quality, but prone to problems.
Mar 30, 2008 | Canon PowerShot A75 Digital Camera
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Vertical lines in screen / Blurry pictures
Hi there, please check this link: http://www.imaging-resource.com/badccds.html Sony will repair your camera free of charge. Best regards, Arpi
Jun 20, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Fuji FinePix F650 Digital Camera Logo
161 people viewed this question
Top Fuji Cameras Experts
Ekse
Lee Hodgson
Lee Hodgson
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
