Try playing around with the H and L screws but it gives me the same problem
SOURCE: Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
SOURCE: Hi, I have a Stihl 192 MS, a climbing saw.
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: 044 stihl sawchain wont idle just dies out and
This sounds like an air leak. Checking all of your hoses and making sure the crankshaft seals are good is where to go after adjusting the carburetor to factory settings.
remove the muffler and make sure the engine does not look like this:
Consult a gold certified Stihl dealer like www.arcolawn.com for parts and tools to repair all of your Stihl equipment.
Good luck
