SOURCE: printing blank pages
My printer has funn ink cartridges and it is printing blank pages and it is saying that the ink is empty. Please help
SOURCE: printing black shaded on complete page
I assume you mean the pages are coming out dirty or gary versus white and black text.
change the drum/cartridge, if you get the same results it could be the hi-voltage power supply. most common is the drum.
SOURCE: MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
SOURCE: Printer prints blank pages from notepad, word, and excel.
Hi tim8094
Obviously there is nothing wrong with the printer, because you are able to print from the Internet.
Before attempting to print from word, excel etc, make sure you have the correct printer selected (check it through FILE MENU -> PRINT ->PROPERTIES)
Do a print test by typing just couple of words -may be in different color-
Best of luck
luciana44
SOURCE: Brother MFC 7840 W printing blank pages no text or images
Had the same thing happen. Unplugged the power on the printer and plugged it back in. No problems now.
Try to re-seat the cartridges in the printer. Open the printer
cover > remove the cartridges > close the printer cover > re-brick you
printer by pulling out the power supply - black box behind the printer where
the power cord is plugged in, and re-plug after 10 seconds. When the printer
turns on, reinsert the cartridges and close the cover. Try to print a document
again to verify that the problem is fixed.
If that doesn't help, the problem could be due to a clogged print
cartridge nozzle. Please follow the steps below to fix print quality issues
with your model:
From the Maintenance tab, select Clean to fix horizontal streaks.
Your printer will then print a page forcing ink through to clean the print
cartridge nozzles.
After printing the test page, try to print a document again to verify that the problem is fixed.
