Sim card registration failed
It may be because of your mobile is locked with any other network .To check that your mobile is locked or not do the following,
Switch on your mobile phone with a sim card from a network other than the network you are currently with. If you are able to use the phone, you can be sure that your phone is not locked. If your phone displays an error message saying "Wrong sim" or "Incorrect sim" or "Emergency calls only", etc., then your phone is probably locked.
If it locked means you can unlock it by getting the unlock code and instruction from your locked network service provider or any other online vendor like Unlock Zone Unlocking the Nokia Asha 205 mobile phone
Try a new sim card
SOURCE: SIM CARD REGISTRATION failed, N70
Factory resetting the phone will do absolutely nothing with this problem
There are 3 causes of Sim Card Registration Failed, when you first turn on the phone, the sim card attempts to connect to the network if it can not do this it gives a message like Sim Card Registration failed.
1, The sim card is turned off (is it Orange) if you have had the sim card for a while and it hasnt been used they will turn it off, you need to contact them from another phone to get it turned on or get a new sim card.
2, The phone has a hardware reception problem, when it attempts to register itself with the network it can not... There is a reception problem and it requires repairs, this isnt really an easy diy job on this handset.
3, The phone is blocked, i.e reported lost or stolen. Some networks when a phone is reported will allow it to get reception but will not let it make calls, however other networks will not give it reception at all and hence you get a Sim Card Registration failed message.
I hope this helps, these are the causes of the message.
SOURCE: SIM card registration failed, whats wrong?
The first thing to try is put the SIM into another handset - if you get the same error message on that, the SIM is blocked. If it works in another phone, the most likely explanation is that the IMEI of your phone has been blocked by the network.
SOURCE: my nokia 5800 says sim card registration failed
your sim card is blocked so change the sim card
SOURCE: nokia 5130 sim card registration
Try another SIM Card to your phone & please verify that your card has been installed properly.
Thanks.
SOURCE: Can you Solve my "sim card registration failed"
when i insert my sim it says "sim card registration failed" this is a problem on my nokia e63
