Order # 103-4056447-9050618, I received my DVD order of the complete dvd collection of Dark Shadows, however, I DID NOT RECEIVE THE 96 PAGE BOOKLET with the order. Nor did I receive a packing slip. The 96 page booklet was advertised to be included with the dvd's, in the brochure I received in the mail. The brochure also said this complete set and booklet was available only on Amazon.com. PLEASE ADVISE IF YOU CAN SEND ME THIS BOOKLET. THANK YOU.
SOURCE: receiving amazon e-mail gift card
Hi larry,
A quick call to amazon will reveal the answer to your question. The number is available once you sign into your account.
anaanymous
SOURCE: Canon 3200 - trying to do booklet printing, saddle
Are you sure that the original documents fed through properly? If the document feeder double feeds then the machine will think that there is only one document, the first one. If the machine does not through up an error then this may well be the problem. Check with normal copying first. Also remember, you would need at least 5 or more documents to make a booklet as each page has 4 A4 pages reduced to A5.
SOURCE: Micro Receiver Lost - Need to order replacement MX-620
I had the same problem. UK will not provide dongle only, but US will at http://www.buylogitech.com/store/logius/en_US/DisplayCategoryProductListPage/categoryid.13029100?WT.ac=sc| if you have someone who can forward it to you - they don't deliver abroad.
Alternativey a standard bluetooth dongle worked for me , but I needed an alternative mouse/keyboard to boot with
Sounds like your "Outgoing" mail server settings aren't correct.
Yahoo! E-Mail Server Settings
Yahoo Incoming Mail Server (POP3) - pop.mail.yahoo.com (port 110)Yahoo Outgoing Mail Server (SMTP) - smtp.mail.yahoo.com (port 25)
___________________________________________________________
POP Yahoo! Mail Plus server settings
Yahoo Plus Incoming Mail Server (POP3) - plus.pop.mail.yahoo.com (SSL enabled, port 995)
Yahoo Plus Outgoing Mail Server (SMTP) - plus.smtp.mail.yahoo.com (SSL enabled, port 465, use authentication)
SOURCE: how to layout a two column booklet and then print
There are 2 solutions
1. Use two column format for the paragraph
select paragraph --> Page Layout Tab --> Select Columns in Page setup group --> Select two
2. While Printing --> Select Two Pages in Zoom Option
Pl revert if need more help
Zulfikar Ali
