Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Blows out cold then shut off - Reddy Heater-170,000 BTU Kerosene Deluxe
Coleman furnace running, won't shut off, blowing cold only
Hello, the blower will run continues if 1) the limit switch has tripped 2) the relay on the intergrated control board is stuck Try tapping on the control board and let me know if it shuts down.
Nov 04, 2012 | Heating & Cooling
2006 magcab ac stopped blowing out cold air olny hot air blows out of vents
check the freon charge for the a/c system to low can shut off the cutch
Jul 13, 2012 | Cars & Trucks
Teperature gauge running hot and heater not working
If the car is hot and the heater blows cold air your thermostat is stuck shut or your radiator is really low on water/antifreeze check when engine is cold hasn't been ran like overnight take off the radiator cap and if it is low add so antifreeze/water if heater still blows cold air or water level is ok your thermostat is stuck shut and needs to be replaced.
Apr 08, 2010 | 2004 Hyundai Elantra
Blows cold but shuts down no freeze up
Check the capacitor. It should be a dual capacitor , runs both compressor and fan. This sounds like your problem only because both the compressor and the fan go out together. Good Luck Hope I helped
Dave
Sep 16, 2009 | Dometic Rooftop RV Air Conditioner
My car heater is blowing cold air
The shut off valve on the heater core was left shut during the repair on your coolant system. the repairman forgot to re open the shut off valve . this is the problem. open the shut off valve and, the air will become hot again. as for the gauge fluctuations, the actual gauge may be malfunctioning.
Feb 24, 2009 | 1996 Toyota Corolla
I have a 1999 Dodge Ram 1500 the air blows out ice cold for about 20 min. and then just shuts off what would cause this I put a gauge in the vent and it was blowing out 38 degrees
I have a 1996 Dodge Ram 1500 club cab. I have had my a/c recharged but it is only blowing barely cold air. It used to shut down when I accelerated and blow hot air before. I don't have that problem anymore except barely cold air. Any solutions?
Jul 26, 2008 | 1996 Dodge Ram 1500 Club Cab
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
