Miele G 2670 SCVi 24 in Builtin Dishwasher Logo
A
Anonymous Posted on Feb 24, 2014
Salt reservoir cracked - Miele G 2670 SCVi 24 in Builtin Dishwasher
What is the meaning of the red arrow light on my Defy DDW236 Dishwasher? I filled with salt yesterday and had to refill again today which is also strange so that light is back on too
On other Defy dishwashers, the red arrow indicates End of Cycle. Thus your dishes should be clean and ready to be removed from the dishwasher. See page 14 the manual for the DDW170 here: https://www.newappliances.co.za/uploads/documents/DOWNLOAD%20MANUAL%20DDW170.pdf . On page 6, the manual states that the add salt indicator can glow for an extended period after you add salt. This is due to the time needed to dissolve the water softener salt in 1 liter of water. Do not add more salt than the reservoir can hold (2 Kg for the DDW170).
I hope this helps.
(Note: if the salt reservoir was dry, you need to add water before adding the water softener salt.)
Oct 14, 2020 • Dishwashers
Hi my kleenmaid silent system think it's a dw2 the salt button is flashing you turn it on it goes to start then stops we cleaned it all out and fix the problem once before but this time nothing works. I'm...
If water is soft in your area you can ignore the salt indicator light and operate the dishwasher without adding regenerating salt. However, you need to ensure the salt reservoir is filled with water to the brim. So add water into the reservoir and then put the cap back on.
Dec 26, 2014 • Dishwashers
How can I drain a water softener
Are you talking about the resin bed or the salt reservoir?
Salt Reservoir ~ Remove as much salt as possible then dump the water out.
Resin Bed ~ You do not want to remove the water from this unit. Disconnect it from the water supply and discharge and cap it off.
Salt reservoir
Yes. The water flows throught the reservoir regardless. The only difference is the salt indicator in the front dash will not lit.
Why is there water in salt reservoir when bypassing or is that normal?
There is always residual water left in a brine style water softener.
1helpful
Our water is soft and does not require salt. how do we stop the red light
I think it might depend on the model # and it should be in your manual.
Example for a G858 SCVI plus instructions (without pictures) are;
Bypassing the salt indicator
If your water is soft (below 8 gr/gal) the
salt reservoir should not be filled with
salt. The indicator will remain lit and
should be disregarded or bypassed.
Remove the salt reservoir cap.
Looking into the salt reservoir, you will
see the top of the float chamber on the
right hand side, a.
Using a screwdriver, carefully pivot
the float chamber towards the center
of the reservoir.
Using needle nose pliers, pull the
cap, b, off of the float chamber, and
remove the float, c.
Replace the float chamber cap, push
the chamber back into its upright position,
and replace the salt reservoir cap.
The "Salt" indicator should no longer be
lit.
Salt not working through into the system
Salt will sometimes "bridge up" at the bottom of the tank.
Sometimes a "soft" persuasion to break up the bridge is required to get the salt to settle down where the water will dissolve it.
I generaaly use a rubber mallet to lightly tap on the outside of the salt tank. If successful, you can hear the salt bridge break up and fall to the bottom and the salt above will start to settle also. Once the salt has settled and it is using the salt, then keep the reservoir full to keep other bridging from forming.
If you are unable to break up the bridge, then the unit may have to disconnected and harsher means used to break up the bridge.
I would recommend that a technician perform this task.
10helpful
Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Top Miele Dishwashers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
