Question about Wega Mininova EPU Espresso Machine
My cuisenart 12 cup thermal coffee maker makes bad coffee. I can't return it as it was a fathers day gift. coffee always tastes bitter and burnt. at work we use the same coffee in a 20 dollar sunbeam cheapo machine. coffee at work tastes great all day long! we have very hard water where i live and work (softener at home not at work). Why does my home brew taste like %[email protected] ?
Posted by swheeler71 on
Anonymous
  • 10,865 Answers
The quality of the water is responsible for the flavor of the coffee. If you have had this coffee maker for a while it is probably coated with lime. Run a couple of cups of vinegar through it followed by a couple of pots of clear water. That will clean up your machine.
Once it is clean, try making a pot with bottled water, or water that you run through a water filtering pitcher.
You will be amazed at the differenct.
Posted on Jun 11, 2009
1helpful
Coffee tastes bitter
two days is not enough for the machine to scale or get dirty from old grinds usually would be either coffee or water problem ---but depending on machine you have didnt specify- can be residue from plastic or container try running a vinegar cleanse than 3 just fresh water then try a coffee drop and see it taste is any different if no change bring back for a refund or exchange
Bitter taste
You will likely find the bitterness is a function of your coffee bean choice or the 'roast' component of that coffee. Darker roasts tend to taste bitter.
Coffee has a bitter, plastic, toxic taste. Even after cleaning and running many cups through new machine
Debris was left in the chamber when manufacturing the unit. Flus and clean accordingly and it will survice.
Ran descale program and coffee still tastes funny (bitter)
If you are using a Claris filter, please remove this from the watertank. The descaling agent will clog the filter and make the water taste bad. After descaling, also be sure to rinse the watertank so there`s no resedue of the solvent left in the tank.
However, bitter taste on the coffe usually is related to the coffee side; Try to run a cleaning program. And check grinder settings. If the powder is to fine, it will increase the contact time, and that will make the coffee bitter. My advise is to clean the machine and experiment a little with the grinder settings.
How much coffee do I use for a 42 cup coffee make
I use 1/3 cup per 12 cups ,depends on your own taste.Try one cup and adjust amount to desired taste.
2answers
My coffee tastes bitter and water is not hot
You need to delime or descale the unit with white vinegar, that will clean it out
Go here to get the manual and it will tell you how to do it....
http://www.retrevo.com/support/Delonghi-EAM3500-Coffee-Makers-manual/id/3878ci577/t/2/
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
1helpful
Coffee is really bitter and doens't taste good
hmm well it wouldn't surprise me. I'm glad you were able to get to the bottom of it! ;) have a great day and enjoy your Keurig!
My Bunn is taking forever to brew and the coffee
It sounds like the thermostat might be allowing the water to boil and cause the grounds to be scorched and making your coffee bitter. It also could be caused by the machine needing to be cleaned and delimed. I would recommend you do this first-and if you don't have the use and care manual, you may call Customer Service to have one sent out or access one at www.bunn.com @ home, then products.
2answers
Saeco Aroma now only produce bitter coffee...
besides a good coffee machine, 2 things are critical when you want a good cup of coffee; the coffee itself and the water. When in France, i tasted some of the best coffee I have ever had, but they always told me that the quality and purity of the water made for 50% of that great taste. Has your municipality changed anything about the water treatment recently? Do you drink that same water and find it tastes funny? Perhaps bottled water is a solution in your case. Hoping this helps.
Marc
Metal Tasting Coffee
vinegar is not the best it remove calcium in little piece descaler produit melt go buy the descaler produit 1part descaler 1 part water put in water container start the machine after a few second turn it off leave it there for 15 minute repeat untill empty rinse very good after that product is corosif 2 or 3 full rinse thanks for using fixya pierre
Wega Mininova EPU Espresso Machine Logo
Top Wega Coffee Makers & Espresso Machines Experts
Pierre Laplante
Kolbrun...
Ross Keen
Are you a Wega Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
