Sanyo DS20930 20" TV Logo
Question about Sanyo DS20930 20" TV
Power on okey bat vertical fold over up down - Sanyo DS20930 20" TV
I have a 2003 chevrolet tahoe how do I fold The seat down
The second row is folded by first pulling up the rear of the seat cushion and folding up 'til it's behind the back of the front seat. Then the back of the seat folds down where the seat cushion was.
The third row seats have several levers that are numbered in the sequence they are to be operated. First fold the seat back down on to the cushion and then flip the whole seat up 'til it's vertical and latched.
This is described in the Owner's manual if you can find one.
When you turn on set a lot of vertical scramble lines
Turn off, disconnect power for a couple of hours and try it again.
If vertical lines still there google for your model number and vertical lines. If it is an LCD version set then youtube search for your model number and repair. Sometimes it takes a baseball bat!!!!
2answers
My boot wont open
If the back seat folds down you can get in and take the cover off the boot lid and pull the levers to the lock and it will open. If the seats do not fold down you have to remove the back seats to get into the boot or just get a locksmith
I need directions on how to fold a 5' Easton Multi-Net....
Go to the link below scroll down to the videos and it will tell you how to fold.
http://www.eastonbaseball.com/5-pop-up-multi-net.html
Good Luck
1helpful
A black line (about 2 inches wide) appears at the top of the screen with this amount of the picture looking like it is folded down translucently over the remaining picture. What's up?
Hello
Your TV has vertical fold problem. Just check all the electrolytic capacitors. On checking, most of them may look good. But on circuit, when energised, will show problems. So it is best to replace all of them once and check. Please check the electrolytic capacitor connected to the vertical power supply [usually comes from the secondary supply section of the Line Output Transformer], first, and replce it. It may be a 1500Mfd or 2200mfd. Check it first by replacing a new one. In most foldover cases, this service will solve the problem. [email protected]
2008 Chev Suburban 4wd Z71 1/2 ton; several items on my passenger side stopped working: my passenger side front seat heater stopped working; the passenger side electric mirror stopped working; the signal...
Power windows an locks work ok ? Do you know anything about automotive electeronic control modules ?
Power Mirror System
Power Mirror System Components
The power mirror system consists of the following components:
• Driver Door Switch (DDS)--An electronic control module with integrated switches and requires programming when replaced
• Passenger Door Switch (PDS)--An electronic control module with integrated switches, requires programming when replaced
• Power Mirror Direction Switch--Integrated into DDS and is a 4 position momentary switch that provides a signal input to the DDS for up, down, left/extend and right/retract with a mirror switch activation
• Mirror Select Switch--Integrated into DDS and is a 3 position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• Left Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Right Outside Power Mirror--Contains both the vertical and horizontal mirror motors
• Body Control Module--An electronic control module that requires programming when replaced, serves as the power mode master and is the main message handler
• Memory Switch, if equipped with memory mirrors--Supplied power by the DDS and provides a voltage signal to the DDS upon a switch activation
• Horizontal and Vertical Position Sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDS/PDS and provide a variable voltage signal to the DDS/PDS that is proportional to mirror position
• Powertrain Control Module (PCM), if equipped with memory mirrors--An electronic control module that requires programming when replaced and provides the message indicating transmission gear selection
• Driver Information Center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a an electronic control module that requires programming when replaced and is used to personalize the memory recall functions
• Fold Motor, in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
Each of the outside power mirrors contains 2 reversible motors to provide horizontal and vertical movement of the mirror glass. The vertical motor operates the up and down directions and the horizontal motor operates the left and right directions. If equipped with power folding mirrors, each outside power mirror will contain a reversible fold motor to operate the extend and retract functions. Each of the mirror motors are circuit breaker protected.
Do you know what DTC'S - diagnostic trouble codes are ?
DTC B1023
Circuit/System Description
The driver door switch (DDS) and front passenger door switch (PDS) each contain switches that control power door lock and window functions. The DDS also contains the control switch for the power outside rear view mirrors. These switches are integrated within the door control modules and are not serviceable as separate components. The DDS and PDS monitor these switch inputs for internal faults and set B1023 00 if any are detected.
You could have any number of problems an without testing , hooking up a scanner that can check DTC'S in the door module ,electrical circuit testing etc... we'd only be guessing . Your best bet mite be to take it to a qualified repair shop.
2003 gmc mirrors do not fold in
The power mirrors are controlled by a module (computer) DDM - drivers door module an the PDM - passenger door module .
Folding Mirror System
Folding Mirror System Controls
The folding mirror system requires signals from 2 separate switches. The mirror select switch must be in the neutral/fold position and the mirror direction switch must be activated to the left/extend or right/retract positions. Both switches are integrated into the DDM and provide direct signals.
Folding Mirror System Operation
Upon receipt of the required switch inputs the DDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function. The DDM will also send a class 2 message to the PDM indicating the requested function. The PDM will supply battery voltage and ground to the mirror fold motor control circuits to perform the requested extend or retract function.
Power Mirror System
• The driver door module--Class 2 module with integrated switches and requires programming when replaced
• The passenger door module--Class 2 module with integrated switches, requires programming when replaced and also contains the RFA receiver
• The power mirror direction switch--Integrated into DDM and is a 4-position momentary switch that provides a signal input to the DDM for up, down, left/extend and right/retract with a mirror switch activation
• The mirror select switch--Integrated into DDM and is a 3-position switch that allows the operator to select the left or right mirror and also a neutral/fold position
• The left outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The right outside power mirror--Contains both the vertical and horizontal mirror motors and is serviced as a complete mirror assembly
• The body control module--Class 2 module that requires programming when replaced, serves as the power mode master and is the main message handler
• The DDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The PDM 10A fuse--Located in the I/P fuse block and is hot at all times
• The memory switch, if equipped with memory mirrors--Supplied power by the DDM and provides a voltage signal to the DDM upon a switch activation
• The horizontal and vertical position sensors, if equipped with memory mirrors--Supplied a 5-volt and low reference by the DDM/PDM and provide a variable voltage signal to the DDM/PDM that is proportional to mirror position
• The park neutral position switch, if equipped with memory mirrors--Provides transmission gear selection information to the PCM and is used for memory recall and mirror tilt in reverse functions
• The powertrain control module, if equipped with memory mirrors--Class 2 module that requires programming when replaced and provides Class 2 message indicating transmission gear selection
• The driver information center (DIC), if equipped with memory mirrors--Part of the instrument cluster which is a Class 2 module that requires programming when replaced and is used to personalize the memory recall and mirror tilt in reverse functions
• Fold motor in each of the outside mirrors, if equipped with power fold mirrors--Provides extend and retract movements of the mirror and is serviced as a complete mirror assembly
DTC B1722
The driver door module (DDM) and passenger door module (PDM) switch the mirror fold motor control circuits to battery voltage and ground in response to mirror extend or retract command.
Electric Mirrors do not work (Drivers & Passengers)
There are two power wires to the DDM - drivers door module .Both are orange ,one is powered by a fuse DDM fuse 15amp . in the left I/P fuse block , plus LT DOORS 25amp circuit breaker .
Do you know what DTC'S are ? Diagnostic trouble codes
DTC B1544, B1600, or B1605
DTC B1580, B1590, B1610, or B1620
• If DTC B1580 is set by itself, the left horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1590 is set by itself, the left vertical position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1610 is set by itself, the right horizontal position sensor signal circuit maybe open, shorted to ground or battery
• If DTC B1620 is set by itself, the right vertical position sensor signal circuit maybe open, shorted to ground or battery.
• If DTCs B1580 and B1590 are both set, the left 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
• If DTCs B1610 and B1620 are both set, the right 5 volt reference or low reference circuit(s) maybe open, shorted to ground or battery.
Need a factory scan tool to test !
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, observe the mirror horizontal and vertical position parameters in the Driver Door Module (DDM) and Passenger Door Module (PDM) data lists.
Operate both the left and right mirrors through the full range of movements.
Does the scan tool indicate that the left and right mirror horizontal and vertical position parameters are within the specified range?
0.50-4.75 V.
Your best bet , take it to a GMC , Chevy , buick or cadillac dealer
Could not Copy Autoexec.bat
hi okey u have not mention which os ur installing pls go through this link it will help u much http://www-304.ibm.com/jct01004c/systems/support/supportsite.wss/supportresources?topicind=103&catselectind=0&brandind=5000008&familyind=5093441&typeind=5093452&osind=5118054&taskind=1 thanks
Solution
You have a bad vertical output IC or a bad capacitor(s) in the vertical driver or output circuits. Not a job for the user to do unless you have the proper tools as well as a service manual. Good Luck
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
