Question about Canon LC-3175 Laser Fax
Delete memory? - Canon LC-3175 Laser Fax
My 5800musicexpress phone momery is full so how can delete my phone momery
Hello there,
If your phone should come up with the message 'memory full' it simply means there are too many files on the phones memory and requires you to delete some so its memory space will be free.
shortcut To delete the files from your phone memory i quite simple. All you have to do is try to snap a picture using the camera, it will tell you the phones memory is full and ask if you want to delete some files, then it will show you the files to delete from, either picture files, videos or songs, then you navigate to the file you want to delete and select and delete then.
Then there will be free space on the phones memory.
Thank you for using fixya.
caseytech
Jun 27, 2011 • Cell Phones
2answers
I canT recieve and send a messaage because my phone says that ' memory full, delete some data first" and i didn"t know how to delete that said data.
you need to delete some of your texts also go to your setting and click auto delete on it will delete the last one everytime you fill up your box so you will never run out of space.
2helpful
How to delete pictures?
To delete the images from the Camera, press the Play button on the Camera to view the images. Display the images which you want to delete and press the DELETE button (Recycle Bin icon) located below the lower left of the Control buttons.
To delete multiple images, slide the index lever and select with the control buttons.
While the index screen is displayed, press the Delete button and select the images with the control buttons and select Enter button. Now, select the images which you want to delete and press the Enter button to display the Delete icon on the images. Press the Delete button again to delete all the images.
You can also delete all the images in the folder by selecting All in this Folder to delete the images.
To delete all the images in the Memory Stick you can select the Format option from the Internal Memory Tool or the Memory Stick Tool Menu to Format the Internal Memory or the Memory Stick.
Thanks for using FixYa.
Delete the password from mmc 5130c-2
My nokia 5130c-2 memory card has a password which i cannot remembered. Can you please help me how to delete it without deleting my files inside that memory?
34helpful
4answers
Memory full, delete some data
  • Click on Messaging.
  • Click on options follwed by settings,
  • Click on Other
  • Select Memory in Use Change it to memory card.
If you Memory card is also full. Backup all your data  to your PC and delete some data in your mobile.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
1helpful
6280 memory full
Steps to follow when the phone memory is full:
  1. If the message memory is full you’ll be shown Memory full. Unable to receive messages is
  2. To delete old messages, Select OK and Press Yes and the folder.
  3. Navigate to the desired message and Select Delete.
  4. Choose Mark, to delete more messages. Mark all the messages you want to delete, Choose Options and Press Delete marked.
1helpful
3answers
How to delete phone memory from a nokia 6070
Hi-
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu >
Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code.
To delete a contact, search for the desired contact, and select Options > Delete contact.
To delete a number, text item, or an image attached to the contact, search for the contact, and select Details.
Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image.
Deleting an image from contacts does not delete it from Gallery.
Pls rate as fixya if it helps, THANKS!
Deleting pics from memory stick
Option Go to list of pictures and check any menus like(mark ,mark all.delete all ) if have option mark menu -just mark all pictures and select delete. opton
2 if you have mark all -just -mark all -and delete
3.if you have delete all -just -delete all -it will delete all of your pictures in memory card
IF NOT OK
IF YOU REALLY delete all pictures and all datas
4.if you wish to do Formate the memory stick
now your Memory stick has Empty.
1helpful
2answers
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 • Cell Phones
Deleting Photos From The Memory Stick
Deleting Still images From The Memory Stick This procedure is nearly identical with all of our digital camcorders. The only difference you may find is that there may not be an enter button on your model. If this is the case, the menu dial serves as your enter button when you push it in. * If you want to delete protected images, you must first deactivate the image protection. * An image which has been deleted cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER. 3. Using the (FWD) and (REV) buttons, search for the still image that you want to delete. 4. Press the MENU button. 5. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The MEMORY SET submenu will appear. 6. Turn the MENU DIAL to highlight DELETE and press the ENTER button. Using the MENU DIAL, select either THIS FILE or ALL FILES and press the ENTER button. *THIS FILE : deletes only the file currently selected. *ALL FILES : deletes all files stored in the Memory Card. 7. A box will appear to verify whether you wish to delete the image(s). Using the MENU DIAL, select the item. *EXECUTE : deletes the selected image(s). *CANCEL : does not delete the selected image(s) and returns to the previous menu.
Canon LC-3175 Laser Fax Logo
old marine
old marine
Ekse
