Whirlpool MH1150XMQ Microwave Oven Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool MH2175XS microwave/hood combo with oil leak, etc.
The microwave is 2 years old. about 5 weeks ago I noticed a drop of oil hanging from the ceiling in the back right, by the edge of a perforated area in the ceiling. There was a small puddle on the floor; the oil tasted like mineral oil. This has happened about once a week. Today when reheating a cup of coffee, it sounded like there were a few kernels of popcorn in the oven. There was just the coffee, which got hot. any
suggestions about the cause and solution to this problem? Thanks for the help.
James Greene
Level 2:
  • Expert 240 Answers
  • Posted on Jun 11, 2009
James Greene
Expert
Level 2:
Answers
240
Questions
0
Helped
138139
Points
560
This is a very wierd problem that we have been dealing with for years, and never seem to get a correct answer. Have actually seen green slime like oil inside the units before. From what we have heard, is that this oily substance is actually coming out of the blower fan assembly inside the unit. Its like bearing oil from the center support shaft. Will go away over time, but the fan may or may not go bad. Good luck with the mystery oil.
Jeff Gillis
Level 1:
Problem Solver:
  • Contributor 20 Answers
  • Posted on Dec 09, 2015
Jeff Gillis
Contributor
Level 1:
Problem Solver:
Answers
20
Questions
0
Helped
6207
Points
59
Most likely if this is hood/microwave combo, the oil is actually cooking oil that has made it past the filters and collected on the cold metal inside, and is now finally dripping of the unit. I had the same problem with a GE Spacesaver, and upon investigation, found that the exhaust air has little or no ducting inside the unit, and when I was browning meat etc, the oil drawn up cooking was coating everything inside with cooking oil, and then on warm days, it came dripping out all over the place, including inside the Microwave that protects the spinner.
Powers off immediately after starting
My immediate reaction would be to cut your losses and buy a new unit as sooner or later you will run into a part that is no longer available.
My microwavedoesn't heat is there a fuse that may be blown
No! the fuse is fine, there are three likely causes, magnetron, "heats food" cracked high voltave diode, or a shorted high voltage capacitor.
PLEASE HELP!!!!!! I had a house built 6 years ago and had an over the range microwave installed. The first one that came with the house was a GE. after like 6 months it would run for a few seconds and...
It may be that the exhaust duct is blocked or the filter is dirty.
That can cause the oven to run chronically hot, which damages the microwave.
The whole duct needs to be checked for any blockage.
You will need to remove the oven from the wall.
To remove it from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
My mh2175xsb microwave quit working a few days ago, that is it pretends to be working. All functions appear normal, timers, lights, fans, and even cycles when on percentage heat, but it heats nothing. The...
Hello Keith Sprague,
Spelling is close and your guess is quite excellent...
Before you ENGAGE in a wholesale repair effort...
You should check your machine is not in DEMO mode...
Demo Mode
Activate to practice using the control without actually turning on
the magnetron. Touch and hold number pad "3" for 3 seconds. The
"DEMO" icon will appear in the display. Repeat to exit Demo Mode
From page 3 (of your operators manual)
Whirlpool MH2175XSB User Instructions Electrical Requirements
Hope this helps
Carnac the Magnificent
Need vent grille for Whirlpool MH2175XS
Go to www.partselect.com and type in the model # you will find it there.
1helpful
Have whirlpool gold accuwave micro hood combo model# GH51884XPS5
The inspector is correct, air should be coming through the top louvers, although you sometimes will have a little air coming from the sides and back. Drop the microwave and see which way the blower is rotated, towards the louvers or towards the back or top. Some units also have a panel that blocks the venting from going the wrong way. Good Luck, Appliance Specialists
Clock and timer on Whirlpool GH7155XHS micro/hood are running slow. Clock loses about 10min/hr and kitchen timer countdown is slow.
I've just fixed a very similar problem with a 10-yr-old NEC microwave oven.
Disconnect AC power, take the top cover off, go through the unit and tighten all screws, particularly those connecting ground wires to the chassis and those fixing major components like the power transformer and magnetron to the chassis.
2 year old ge profile spacemaker Microwave lost all power
Inside unit is a cylinder fuse which can blow for a number of reasons. External cover needs to be removed to access. If you are confident in doing this and can find & check the fuse then it would be my first guess. If fuse is OK then you will need to have repaired. If fuse isblown & you replace then it blows again,you will need to have repaired. regards
Top Whirlpool Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
