Sony videoscope xbr
I have a problem with my Sony Videoscope XBR and the problem is that when i turn on the tv, the screen goes straight to that black & white scrambling screen. The sound if fine, it's just that the picture doesn't appear when i turn to different channels, but when i watch a dvd, the picture is perfect. It's just only when i watch cable...all it shows is the scrambling black & white screen.
Posted by angielaogurl on
Russ Hill
  • Televison & ... Master
  • 4,057 Answers
Would think you need to replace the cable board etc. the signal is not getting in and out right. can also be a fault on the power board giving the wrong volts so would check this to. it will tell you on the board what volts is supposed to be. the 5v and 12v should be spot on other volts will vary a little. also check the capacitors for the caps to be bowed up and a brown/ yellow gunk around them and under the board this can be a sign they are failing.
Posted on Feb 26, 2014
5 Related Answers
Cybertech
Jose Zetino
  • 149 Answers
SOURCE: Sony Videoscope XBR TV
just need to balance the three colors red,green and blue that may help remove the front covers and look for black module that have sccree and focus controls just move a little bet left or right be carefull because you can loos the picture e-mail me for more info
Posted on Apr 08, 2008
Anonymous
SOURCE: TV not working- Sony Videoscope XBR
I don't Know how the caption come out
Posted on Oct 21, 2008
ABRsvcs
  • 4234 Answers
SOURCE: TV has sound no picture, Sony Videoscope xbr
Please post both the exact model number (on the back) and the blink count. The standby light should be blinking a repeated pattern. That info will indicate the problem circuit and allow us to provide you with the proper parts/steps to resolve this.
Thanks,
Dan
Posted on Feb 10, 2009
Anonymous
SOURCE: Can a Sony Videoscope XBR TV be separated into pieces to move?
We moved it in one piece.
Posted on Dec 03, 2009
OLUWASEUN SANYADE
  • 184 Answers
SOURCE: Sony videoscope xbr TV screen keeps blinking in
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem
Posted on Aug 06, 2011
My sony videoscope XBR tv has a pink picture and no control. Also nothing is in enlish.
the model listed is a very old set---parts may not be available----language can be selected in the menu but the pink may be a adjustment of the screens (controls) or a circuit problem.
Aug 26, 2012 | Sony KP-53XBR45 53" Rear Projection...
Can't turn off pip on sony XBR videoscope TV
Look on your TV remote and press the button clearly labled PIP or Picture-In-Picture and press that button over and over. It will cycle through all the PIP modes until it turns it off!
May 02, 2011 | Televison & Video
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
Jun 11, 2009 | Mag Innovision InnoVision XJ 717 Monitor
Thanks,
Dan
Feb 10, 2009 | Sony KP-53XBR45 53" Rear Projection...
Sony Videoscope XBR 53
This is a convergence problem. Look in the back for a couple of large black ICs attached to a heatsnik. These should be marked STKxxx. These are the convergence ICs and either have bad connections or are defective. If you can solder, try resoldering the pins on these ICs. If that fails to resolve the problem, replace the ICs. There may be other parts that need to be replaced as well. I'll look up your model to find the other parts to check. The convergence board as an assembly, I believe, is no longer available. The parts that you require are available.
Dan
Sep 18, 2008 | Televison & Video
Sony Videoscope XBR
from experience i have noted that after some time the Horizontal Out-put Transistor (HOT)gets worn out.This is a big black transistor starting with cd,d,t etc mounted on a big heatsink.note the numbers and replace it.
Aug 01, 2008 | Mag Innovision InnoVision XJ 717 Monitor
Sony videoscope xbr
the problem is most likely to be found on the HOrizontal Output Transistors note their numbers and replace them.this transistors are usually mounted on huge heatsinks.
Jul 05, 2008 | Mag Innovision InnoVision XJ 717 Monitor
Apr 07, 2008 | Sony KP-53XBR45 53" Rear Projection...
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
