Question about LG Computers & Internet
LG Escape ROM
Please help me with my LG escape. The problem is that my phone got bricked because of wrong recovery. Every time I connect it to the computer to unbrick it, it says qusb-loader mode. The screen is always black. I know it is something with the the physical ROM in the motherboard. Please Help, Thank You.
Posted by Hammaad Iqbal on
Noah Denza
    New Friend:
  • 35 Answers
Here is a link to a solution to unbricking your lg phone I hope this helps
GUIDE UNBRICK ROOT FLASH Any LG Factory ROM kdz WITH OFFLINE FIX GSM...
Posted on Feb 25, 2014
5 Related Answers
Anonymous
  • 2351 Answers
SOURCE: how to connect a power in motherboard?
Hi zarathoustra, still have your manual? Go to page 25.
As shown here.
26b4ba3.jpg Little fuzzy.
Need your manual, click this link.
http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000010
Suggest you save the link.
Good Day!
Mike
Posted on Apr 03, 2008
Anonymous
  • 2351 Answers
SOURCE: how to connect front pannel
How about a picture? Pg. 46 in your manual.
Need manual, download from Intel. (Click on link).
http://www.intel.com/support/motherboards/desktop/RC440BX/sb/CS-013608.htm
Intel RC440BX Specification
Pg. 46
Basic rules case wiring. The color black is considered ground -. Power wires + can be any other color including stripped wires. (This is standard but case Mfg change to their own specification).
Pin 1 is + power for LED Hard drive green LED, Pin 2 is -/ground for Hard drive LED.
(Pin 3 is + power for LED Hard drive yellow LED, Pin 4 is -/ground for Hard drive LED).(See more options on pg. 47).
Pin 5 is + power for case On/off button, Pin 6 is -/ground On/off button.
Pin 7 is + power for Reset Switch, Pin 8 is -/ground for Reset Switch.
Once positive & negative pins has been located each connector follows in suit.
The Intel RC440BX front case connector is in an odd location.
The user will find it hard to connect front case LED connectors while the board in installed into the case.
Good Luck!
Mike
Posted on Apr 25, 2008
Niraj Limbu
sanjay Limbu
  • 183 Answers
SOURCE: D-drive causing physical/memory dump problems
There might be several causes for it but shortest and best way to get rid off this problem is:
Test your RAM (either its corrupted or not) using testing tool
http://oca.microsoft.com/en/windiag.asp
if you RAM is fine then you being encounter of software confliction or OS corruption.
First: maker sure you Antivirus software is up to date and if it is then uninstall your all games then run full scanning then install only one game and try playing it. if still your problem does not go away then restore your OS setting back:
for that:
insert your disk (os or recovery) in dvd/cd drive (your Disk must be same one which is you have currently installed in your PC)
then
Go to star>Run then type ins "sfc /scannow" without quotes.
then let procedure to be completed by PC.
once you are done just rebood your PC.
if you don't wanna all above hassles then just install fresh OS in your sytem and once you install fresh OS you need to run auto updates for new patches and drivers.
Thanks
and
do note forget to rate answers.
Posted on Jan 01, 2009
Anonymous
  • 54 Answers
SOURCE: ECS 945gct-m2 CMOS error
When you enter the bios...go to the setting where you have the option your reset the bios to manufacturer...Once you do that it will work without any problems...It sounds like the bios setting might have been accidentally modify..
Hope that helps
Thank you
Posted on Mar 06, 2009
Chuck Badeaux
  • 95 Answers
SOURCE: setting up gigabyte ga-686lx3 verion motherboard
Here's a link to where you can get the manual free and it will show you the jumper options and all. Hope this helps.
http://www.motherboards.org/mobot/manuals/Gigabyte/GA-686LX3/
Posted on Mar 29, 2009
How do i make my tecno Phantom Z A7 Stay on, i think i may be bricked it.
reflash it with sp flashtool but be sure that you uncheck the format box
May 14, 2018 | Android Cell Phones
HOW DO I SET THE CLOCK IN MY 2002 FORD ESCAPE XLT
Difficult one that for a old dinasaur like myself ,ask one of the grandkids ? thats what i do when fancy phone doesnt work i use a nokia brick for work .Brilliant phone ,this question is like setting the clock on a old video i never did master that either
Nov 10, 2016 | 2002 Ford Escape
I have 2 locks on my country escape can u please let me have 2 more? Thank You
FarmVille 2 Country Escape Cheats, Tips and Tricks for a ...
www.touchtapplay.com > Game Guides
Apr 18, 2014 - The more items you have producing goods for your farm, the faster and... Ideally, you will have 3 friends added in FarmVille 2 Country Escape to .... I have19 nails in my barn and just one lock so i can not upgrade the ... If you did, please let me know! ... Do let me know if you used the time lapse cheat too...
Top 10 Answers for Farmville 2: Country Escape (Part 2 ...
Dec 26, 2015 | Cell Phones
How do I change the Email on the game Farmville Country escape I put the wrong Email address on the game so please help me change it think you
You can only have one account of FarmVille country escape, uninstall it and then try and link it to faceboo
Sep 29, 2014 | Zynga Farmville
Why does my 2012 Ford Escape over 40 mph have a miss. Nothing comes up on my computer to indicate something is wrong. I have had it checked several times at the Ford Dealership but they cannot find
May be due to a defective coil that can be hard to find. Need to find a good tech that knows how to look at OBD2 mode 6 data for misfires. May show up there even if the light hasn't come on yet or set a code.
Sep 03, 2014 | 2012 Ford Escape
Intake Mainifold hose connection, Escape 2002 V6 3.0L XLT
does the cap look like its always been there ie as dirty as rest of engine etc , it may be not utalised on that model , as for running prob have the OBD codes read as is most probably a sensor
Apr 23, 2014 | 2002 Ford Escape
Soft bricked gtn7000b
"DON'T" use Odin for B15. Use MtkFlashTool or SP-FlashTool.
On XDA Developers you can find the Stock-ROM files incl Boot.img, Recovery and ...!
Read manual carefully and "never never" flash Preloader or DSP_BL except your Preloader is already bricked! In that case you've gotta be really careful not to flash a wrong one. (Phone went Dead and maybe 4 ever)
better try about warranty
Feb 13, 2014 | Cameras
My girlfriend tried to update her phone using the LG official software but in the process has bricked her phone. it wont start at all, can't connect it to pc because pc dosent recognize its there....
try to put your phone on recovery mode press home button then power on the phone and keep ur hand on the home button till it completely boot up leftcorner its written safe mode and try reset the device.
May 18, 2011 | LG GT540 Cell Phone
The phone isn't sim free!
Try out the following key code ##0651321** and your LG KF-310 will be unlocked like a magic.
Jun 01, 2009 | LG KF310 Cellular Phone
Computers & Internet Logo
321 people viewed this question
Top LG Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
