Question about Alcatel Cell Phones
Slot permanently locked
I got a new Alcatel One Touch 5020T and I want to unlock it to use it with AT&T but when I put my AT&T Sim Card it says The Slot Has Been Permanently Locked, how can I Unlocke it? Hel Me Please!
Posted by Alison Stubbs on
Paul Chana
    Master:
  • 576 Answers
Hi Alison,
Try this site..
http://sim-unlock.net/simlock/Alcatel/OT-5020T/
Choose your model and follow the steps. You may have to purchase a code to unlock it.
I would strongly suggest you take it back to where you bought it as you locked the phone by inserting a different SIM. You activated the security feature to prevent it from being used. At this point you need to get the vendor to unlock it... try calling the place where you bought it, and see if they can assist first. Best of Luck!
Posted on Feb 29, 2016
5 Related Answers
Anonymous
  • 192 Answers
SOURCE: locked SIM card
Brother 3 time inserting of wrong security code gives "Enter PUK" message, 10 times entering wrong PUK code gives "Sim blocked" message. If there is "Enter PUK" message u can get it from service provider but if there is "Sim blocked" no one can do anything to your sim. You have to change your SIM in that case. Your service provider can replace your blocked SIM with another new SIM in normal charge. If this answer satisfied u do vote.
Posted on Jan 06, 2008
anthonycouti
  • 3 Answers
SOURCE: Alcatel OT600, VM621i,sim card locked. Need reset key.
can anyone help me to by posting me a reset key key for alcatel ot-s621 mobile
Posted on Apr 03, 2010
Anonymous
SOURCE: my phone is permanently locked how do i unlock it
ask your service sim service provider for PUK No.
to unlock your phone
if it not work go to sevice center of your mobile company
Posted on Apr 19, 2010
Anonymous
SOURCE: Unlock Nokia 3105-CDMA phone non-functional SIM card slot
i also have nokia 3105 cdma mobile with tata indicom as operator in india. i want to make it t-sim enabled as it contains a t-sim slot but not working....so help me out
Posted on Jul 09, 2009
Anonymous
  • 3 Answers
SOURCE: Samsung Star GT-S5230 Unlocked Phone with Full
The sim card is inserted above the battery which is located on the back of the phone. The attached photo shows what you will see under the battery cover. First, turn the phone off. To remove the battery, start by removing the battery cover which is the back cover of the phone. Press on the back cover in the center next to the camera and pull the cover down towards the bottom of the phone. The cover should slide off. Slide the sim card, face down with the "notch" on the top right side of the sim up underneath the small metal receptacle designed for the sim card. If you do not see the receptacle, look for an etching of the sim card on the phone that is above and to the right of the sim card receptacle. wickerjk.jpg
Posted on Mar 02, 2011
I need a unlock code for my alcatel one touch 5054n please please imei#0146**********2
  1. After downloading the unlock application on your device. (Alcatel One Touch unlock code generator)
  2. Then fill in the Alcatel One Touch form. The most crucial piece of information at this point is the IMEI number of your Alcatel One Touch. The IMEI code identifies your Alcatel mobile device among all the other Alcatel devices from the same model. Write the correct IMEI code. You must enter a valid email address where you will get you to unlock Alcatel One Touch code.
  3. Click on the unlock button when you fill in all information about your locked cell device.
  4. You will find the unlock code for your Alcatel One Touch in an email you will receive during this process.
  5. To be able to insert the unlock Alcatel One Touch code in your device and unlock it, you must insert a SIM card from a different network provider than the one you used so far. The new SIM card will instantly be recognized as unauthorized by the lock software in your phone and you will be asked for the unlock code to authorize the presence of the new SIM card. Here you enter the unlock code and you click on OK to successfully terminate the SIM lock on the Alcatel One Touch you own.
  6. Now your phone can accept any SIM card from all the carriers on the globe. There are around 750 different carriers and now you can choose from all of those. To be able to use the data connection of your new carrier you are going to need to insert the APN settings of the carrier you will use from now on. You will get the settings in no time. To replace the old APN settings with the new ones you need to go in the Settings menu, click Mobile Network, then click Access Point Names. Here you must click the New APN option and save the new APN settings. Put your phone in airplane mode for about ten seconds and once you turn this option off you will be able to use the data connection of your new carrier.
  7. Unplug your Alcatel One Touch, remove the battery-cell out, put it back in and turn the telephone ON once again.
That is all, your current Alcatel is unlocked, you can use all SIM card in your mobile from any network all over the world! Not to mention the advantage of improved and higher value in case you intend on selling it, besides having the ability to use your Alcatel with any network.
I need to unlock the network code on my Alcatel one touch mini. I need the code please if anyone can help. It says: Enter SIM ME lock [NP].
I suggest you can approach Simpleunlocking.com and specify the country,locked network of Alcatel One Touch Mini .Based on the availability you can get the permanent unlock service along with free instructions.
What is PUK?
PUK code unlock: ALCATEL ONETOUCH Fierce ' T-Mobile ...
https://support.t-mobile.com/docs/DOC-11783
T?Mobile US, Inc.Jul 1, 2014 - Learn how to PUK unlock the ALCATEL ONETOUCH Fierce™. PUK code ... Entering the wrong code can permanently damage your SIM card.
PIN & password: Alcatel ONETOUCH Evolve ' T-Mobile ...
https://support.t-mobile.com/docs/DOC-7470
T?Mobile US, Inc.Jul 29, 2013 - Learn how to lock, unlock, and PUK unlock the the Alcatel ONE TOUCH... Enter password (default is 1234) in the Lock SIM Card screen.
3answers
How do you unlock a slot when its permanently locked in a dual phone
my phone alcatel orange royal permanent blocked. l buy in another country have a code remain 10times and then blocked
Mar 16, 2013 • Cell Phones
2answers
Alcatel phone sim card locked
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
15helpful
4answers
Hw to get network key to unlock alcatel ot708
Hello
You can unlock phone here
http://sim-unlock.net/sim-lock/3/Unlock_by_code_for_Alcatel_phones/
Aug 06, 2011 • Cell Phones
Cell Phones Logo
Top Alcatel Cell Phones Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
