Question about Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio
Has low volume with volume all the way up
Sounds like it has little power when volume is all the way up
Posted by shaun skelton on
Laron
    Novelist:
  • 146 Answers
You've been close to another big radio......you think that was a question but I believe it is the answer. The rf amp transitor or the diodes in that circuit have been damaged. So that stage of amplification is not stepping it up for the next. Resulting in the electrical power converted to air audio by speaker isnt available. Cb shops refer to this as a blow front end. Tr17 is the transistor location .......just a side note some radios have a mic circuit check that dulls audio levels this is not the case here.
Posted on Jun 14, 2014
I have no volume no sound Would a Hard Reset fix this problem?
A hard reset is worth a try but it is unlikely to fix the problem, it sounds like a hardware issue.
Here are instructions for a hard reset
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
I’m happy to help further over the phone at https://www.6ya.com/expert/jonathan_828b54f422cbefdd
Dec 25, 2014 | Craig CMP741d Tablet
When the volume is low the subwoofer sounds good, but when you go up a little volume, the sound is more acute. I have two subwoofer 1000rms each, when use 500rms power aprox, it sound great, but when
If the sub doesn't appear to have any damage like broken surround or a torn spider then I would suspect the amp may be having problems. What impedance are the speakers, what impedance can the amp handle, how do you have it wired to the amp?
Feb 23, 2014 | Fusion FEW12PK Car Subwoofer
My logitech x240 surround powers on but no sound comes out....what could be the problem??
If you have an extra headset around, plug it into the same place the speakers are plugged into, if it works, your speakers are bad (or check to make sure the power light is on on them and that their volume knob is turned up).
If you still do not get sound, click on your little volume/speaker icon by your clock, then click 'mixer' at the bottom of it (Windows 7 hopefully?). Make sure the different volume controls are turned up because sometimes one low one will affect the entire system.
(If Windows XP, right-click the speaker, then 'Open Volume Control'. Adjust until you hear sound.)
Dec 08, 2010 | Computers & Internet
It shows the speakers are on but no sound
Dec 08, 2010 | HP JBL Platinum Computer Speakers
Very littel sound in white and black keys. normal
We can only guess at what model/brand you have.
OFTEN such low volume things can be traced to a burned out light used in some expression pedals that use light dependent resistors to vary the volume.
Be aware that on some organs things like rhythm drums MAY go through a different set of speakers and amps than the other voices.
Apr 30, 2010 | Music
My computer will no longer play music or any kind of noise
Check that your speakers are plugged into the right jack either in your sound card or the sound panel on the motherboard. If no sound then try plugging speakers into another computer and see if they are working and have power. Go to "control panel" and click on "Sound and Audio Devices" and under the volume tab under Device Volume make sure that the "Mute" box isn't checked. Also check the "place Volume icon in the taskbar" box if it isn't already checked. Go to the Volume control on the task bar and check out the audio volume levels and make sure they're not turned all the way off. Also under "Sound and Audio Devices" underl Volume tab click on "Advanced" and make sure that you have selected the proper kind of speakers in the speaker setup box.
YOu didn't say so, so I'm assuming that you're using Windows XP. If you're not the menus may be a little different but similar.
Sep 29, 2009 | Microsoft Windows XP Home Edition
I have no sound in my computer
Basic troubleshooting steps: If you have powered speakers, are they turned on? Are they plugged into the correct hole on the back of the computer (usually the green one).
In the accessories folder (in the start programs), then choosing entertainment and choosing volume control, is the little box that says "mute" checked? Is the volume set too low?
When you go into the control panel and choose sounds, are you able to play a sound, or is the little arrow that allows you to play the sound grayed out? If so, your sound drivers are missing or corrupt. Then your problem becomes "how do I get sound drivers for my computer?" If you ask this, be prepared to give us more information about your computer, the sound card, etc.
Mar 04, 2009 | Computers & Internet
Output volume varies, with loss of bass and clarity
This sounds more like a power supply problem. I would have the voltaeg regulators checked along with the filter capacitors in the power supply area.
Dan
Aug 29, 2008 | Yamaha RX-V870 Receiver
Microphone isn't working with the computer.
1-select start2-select contrrol panel3-select sound speech and audio devices4-select sound and audio devices.5-confirm that mute box not signed.6-pres advanced in mic volume confirm mute box not signed7-select audio you will see capture screen in mic volume sign select.8-in default device press volume you will see volume control screen in mic volume confirm that mute box not signed
Mar 02, 2008 | Philips PH62080 Uni-Directional Microphone...
Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt Cb Radio Logo
119 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
