Question about KitchenAid Ovens
The first thing I'd suspect is a poorly fitting door seal / gasket. This will permit the heat inside the oven to escape. Check to be sure the the one installed is defective (cut, split, frayed, dislodged, etc.) Replacement parts:
http://www.appliancepartspros.com/whirlpool-gasket-door-w10074200-ap3892420.html
Make sure this is the part you need before ordering.
Posted on Feb 25, 2014
SOURCE: The oven door are not closing all the way
spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not closing...Catriver..post back.
Posted on Sep 03, 2006
SOURCE: neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Posted on Oct 20, 2008
SOURCE: cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Posted on Feb 04, 2009
SOURCE: Stoves 900GDO Bottom oven door seal
The handbook tells you how to take the door off. If you can do this, do so and then clean/spray all the door hinge mechanisms with WD40. Remove the surplus with kitchen towel and replace the door. Operate the door a number of times to see if this has cleared the problem. (Over time the hinges seize up and the WD 40 normally eases this situation).
(Don't be confused with the air flow coming out of the oven from the cooling fan as this also runs along the top edge of the door).
Posted on Apr 04, 2009
SOURCE: Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Posted on Aug 06, 2009
