Question about Health & Beauty
Why won't my bottom blade stay put on my andis t outliner
Posted by camronmoss96 on
heidi muehlenberg
  • 62 Answers
Please watch this Youtube video on how to adjust/replace your T-outliner blades.
Posted on May 12, 2014
5 Related Answers
Anonymous
SOURCE: Andis T-Outliner
adjust the brown plastic on the blade all the way up.remov the blade and the brow plastic is held with screws
Posted on Apr 27, 2008
heidi muehlenberg
  • 62 Answers
SOURCE: i have a andis outliner
The blade has not been lined up correctly when it was put back on. For complete instructions on how to replace the blade please visit the Andis website at www.andis.com. Click on the service tab and then use and care. Scroll down to the model you have and click once more. If you need any additional help please call the Andis customer service department at 1-800-558-9441.
Thank you for choosing Andis.
Posted on Dec 12, 2008
Anonymous
  • 61 Answers
SOURCE: andis outliner
you should not have to send your clipper to be repaired before it is used, the maker of the product should be willing to walk you through the adjustment step by step, because the problem is the blade adjustment,why send a clipper back just to get a blade adjustment,which will take 30 days to return,and you will be out of a clipper,you will lose money in the process, it's simple call and ask how to (precisely) adjust blade, and if that dosent work for whatever reason, return the product and buy from another company, some companies have a way of making more money from you,unnessasarily, in this economy thats a sure way to loose business.
Posted on Jan 28, 2009
Anonymous
  • 8 Answers
SOURCE: adjust blade
On the Andis T-Outliner or Outliner if you have use the trimmer for more than 3 hair cuts or 3 time or more I do not recommend moving the blade, reason why is that you have all ready start or have a sit in or a grooved, I have found that by moving the blade it won't cut at all.You need to resharpen the blade with a professional sharpener and have them reset the blade for the type of hair cut you want. The blade can be set to shave or do line ups, and Fades. This type of trimmer is for that kind of hair cut the professional barber use them all the time. Call Mannys Sharpening 323 263-4697 They have a good rating on Yahoo Local.
I have try many sharpener and had no luck, until a friend of mind told me about Mannys Sharpening, They know what they are talking about highly Professional in thier work.
Posted on Aug 01, 2009
SOURCE: My andis t-outliner keeps pulling hair when
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Posted on Jun 20, 2010
What is andis outliner II correct blade alignment?
Please go to youtube andis to watch instructional videos. If you are still unable to align your blades please call our customer service dept at 1-800-558-9441 for assistance.
Jul 13, 2014 | Andis Outliner II Hair Trimmer
My T-outliners are running correctly but they are not cutting even the smallest but of hair and they are pulling. I have adjusted, cleaned, and examined them thoroughly and cant find a problem, they are...
sometimes the blades don't align properly when we put them back together. try to re adjust the blades, they should be 1/16th of inch apart and be level, also makes sure you are oiling the blades before every use, friction causes wear and they won't last as long.
Jun 12, 2011 | Andis T-Outliner Hair Trimmer
I have an Andis outliner II I purchased a year ago. I recently changed the blade but it won't cut my hair. Do you kow why?
Sometimes the new blades from Andis are not sharpen enough to get that clean cut. also all trimmers need to be readjusted for power and alignment, plus sharpening the blade, it look like you need a complete sharpen & service on your Andis trimmer. check out Manny's Sharpening they have a Mail Order service, the service they provide is fast and they will sharpen make all the adjustment and give your trimmer more power and the blade will cut clean. They will even adjust the blade at your request on how you want that blade to be set at. Line Ups or Fade Cuts and even shave set. Manny's Sharpening been around for over 20 years and they have a very good rating on the net. Check it out Manny's Sharpening
May 21, 2011 | Andis Outliner II Hair Trimmer
I took apart my andis hair clippers and now i can not get the little blade to stay in place is there a trick to this?
i took apart my andis t-outliner & i dont know where to put the oval shape silver pice
May 20, 2010 | Andis 04603 Hair Trimmer
Step by step guide to cleaning blade!! Forgot which peice to put in first!
is this blade andis, oster,wahl detachable blade need to know what type of blade you have to help you
Jul 13, 2009 | Andis Outliner II Hair Trimmer
Want to adjust trimmer so i give a better outline i just bought new blades, not sharp enough
Sometimes the new blades are not sharpen enough, You need to have it resharpen by a professional and adjust to the type of work you want it to do. Also sometimes even if you have the blade resharpen it will not cut, because the trimmer motor needs more power to move the blade side to side faster. On and the Andis GTO T-outliner trimmer this the most comm problem. Try Mannys Sharpening
Jun 15, 2009 | Andis Outliner II Hair Trimmer
I have a andis outliner 2 and it was working fine then i took the blade off to clean it then whten i put it back togather it wont cut like befor, blade does not vibrate like before.
Dec 11, 2008 | Andis Go 04630 Outliner Beard Trimmer
Andis outliner
Andis factory for repairs at 1800 Renaissance Blvd Sturtevant WI 53177
Aug 23, 2008 | Andis Outliner II Hair Trimmer
Andis T-Outliner
Apr 23, 2008 | Andis 04603 Hair Trimmer
Put it back together
Purchase the DVD on "How to adjust your trimmers and clipper blades" at www.alexccampbell.com
Jan 15, 2008 | Andis Outliner II Hair Trimmer
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
ray gallant
Bill Boyd
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
