Question about Husqvarna Lily 540 and 550
Wound thread around the hand wheel
I have managed to wind a large amount of thread around the hand wheel on my Husqvarna. I have pulled most of it out using tweezers but still al small amount is left inside that I can't get. Is there anyway I can open the back of the machine that would give me access to the wheel without messing up anything else on the machine. This is not a bobbin problem it is the hand wheel.
Posted by Barbara Hardy on
deborahcha
    Novelist:
  • Husqvarna Expert
  • 371 Answers
You should be able to pull the cover of the hand wheel off. Just firmly grab the hand wheel and pull straight back.
Posted on Jul 14, 2014
3 Related Answers
Anonymous
  • 87 Answers
SOURCE: Designer 1 Embroidery Bobbin problem
Designer 1 bobbin case tension adjustment:
When the bobbin runs out, sometimes it bends the bobbin case tension spring. Then tension is too light. Take the bobbin case out of the machine. Tie the loose bobbin thread to the Designer 1 needle plate. Insert the bobbin in the bobbin case. Here’s the tricky part set the bobbin case on the table as if it’s in the machine (Bobbin is visible and sitting horizontal to table top) threaded as if sewing and loose end tied to needle plate (that is removed from the machine). Lift the bobbin case off the table rotate it so that the flat side of the bobbin are vertical to the table and no longer horizontal. Have the bobbin case oriented so that the thread coming out of the bobbin case sprint (slot area where it is put for sewing) is at the top. Lift it high enough that the needle plate is lifted from the table. It should not release thread unless you shake it gently and then a very small amount of thread. The needle plate is the exact weight resistance your bobbin case should have on the thread.
Posted on Mar 18, 2009
deborahcha
  • 371 Answers
SOURCE: husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
Posted on Sep 24, 2009
deborahcha
  • 371 Answers
SOURCE: viking husqvarna classica 100, thread tension
I suspect you are correctly threading the machine but the timing of the needle and bobbin hook is off. When the threaded needle goes into the bobbin area, a pointed hook grabs the thread and loops it with the bobbin thread. Something is catching when the needle starts to come up that is not allowing the bobbin thread to be pulled back through the needle plate opening by the upper thread. With machine threaded and bobbin in place, have the bobbin area open if possible and watch the thread interaction when the needle goes down. To set the hook/needle timing, normally covers have to be removed. Suggest taking it to an authorized Husqvarna Viking dealer for service. You can find the nearest dealer by click on the "Dealer" link at http://www.husqvarnaviking.com
Good luck.
Posted on Feb 11, 2010
How do I wind the bobbin?
There are several ways. On most machines you put the empty bobbin on the spine over the bulk of the machine on the right hand side. Twist some threads around the bobbin to get started, then put the thread through the thread loop above the shuttle area on your left side. That keeps the tread tension right. There is a gear the clicks into the bobbin. You push that closed. You will have to release the clutch by turning the large wheel on your right hand side. Not hard to find and it usually is hand size. It is the one that goes around and around when you are sewing. Grasp it firmly and turn the top toward you. This will prevent the needle from going up and down when the thread is pulled onto the bobbin. Don't forget to tighten the large "wheel" when you are done.
Feb 24, 2015 | Sewing Machines
Thread around wheel
If it were my machine I would pull the back cover for better access to the rotating shaft and remove the remaining thread. If the thread works its way into the shaft bearings you will have a real mess.
Feb 24, 2014 | Husqvarna Lily 540 and 550
I only want to know if the wheel must be loosened to wind the bobbin and if so with direction, to the front or backwards and press and turn or pull and turn.thanks
Which make and model sewing machine do you have?
None of my sewing machines need the wheel to be loosened for bobbin winding. The Singer Touch & Sew bobbins are filled in place. Use the handwheel to get the needle into the highest position (just turn the wheel). Wrap the top thread around the screw that holds the presser foot; open the slide plate part way and press the bobbin wind button. Hold the top thread and then begin winding by stepping on the foot pedal.. The thread should break after a few winds.
The Kenmore and the Husqvarna Vikings both get wound at the top. Place bobbin on winding pin. With the needle up and metal presser foot in place thread the top thread up to the bobbin (through the guides) and up through the hole in the bobbin. Slide the bobbin winding switch over towards the bobbin. Hold the thread tightly and begin winding (step on the foot control). After a few winds are on the bobbin, cut the thread that you were holding flush with the top of the bobbin. Continue winding the bobbin. (The newest Viking in the group has a computer screen; on that one, do not press OK until done winding the bobbin.)
However, if the handwheel is not turning and the needle is down, first find out why it isn't turning properly. This could indicate a tangle of thread somewhere in the system. (The older Husqvarna sewing machine in my home has a non-functional handwheel. The machine will still sew but you have to use the needle up/down switch that forces the needle to stop in the up position before you run out of bobbin.)
Please add a comment with the specifics of your sewing machine and I'll be glad to add additional information.
I hope this helps.
Feb 28, 2012 | Sewing Machines
I have a Freesia 425 - I have wound the bobbin successfully, but the bobbin will not come off the winder - any explanations
The bobbin is probably cracked. They get that way when bobbins are wound in correctly, or to tight. Just break it off and get new bobbins. Just make sure your theading it correctly when winding bobbins.
May 04, 2011 | Husqvarna Freesia 425
I wound a new bobbin and now I can't get it on the bobbin winding spindle. I have the exact same problem with a husqvarna 400
When you wind a bobbin on a Husqvarna and you leave the machine threaded to wind the bobbin through the needle, you must take the thread down below the foot (a metal foot only) before you take the thread up to the bobbin winder. If you take the thread directly from the needle it creates too much tension on the thread and crushes the center of the bobbin so that either you can't get the bobbin off the spindle or in some cases it damages the bobbin completely.
Some threads, the kind that can stretch slightly when pulled, shouldn't be wound through the needle at all. Instead go through the first guilde and then straight down to the little metal "button like" guide and then to the bobbin. It will create much less tension on the thread and wind it much better.
Oct 11, 2009 | Husqvarna Designer I
Bobbin won't come off the winding spindle
Your bobbin was basically crushed slightly, to remove it simply take the thread off the bobbin and it will come off very easily.
4d embroidery machine is pulling bobbin thread to front
Not sure what a 4D machine is, but guessing you have a Designer of some kind. Have you put in a new bobbin since you sewed out the successful design? Did you wind it yourself or is it a pre-wound? If wound yourself, maybe the tension on the bobbinfill was not correct and the bobbin is not wound properly as a result. Wind a new bobbin - take the machine speed down three clicks and wind the bobbinfill around the round metal tension bit in a figure-of-eight instead of around once only (i.e. go under the disc, around to the left then over the top then across to the bobbin filling mechanism).
Floss out the bobbin tension slot with a piece of strong sewing thread to be sure there is no fluff in there, and when you re-load the bobbin be sure to listen for the "click" as the thread goes into the tension slot.
Sometimes designs are badly digitised and they will not sew out nicely. If you are sure your fabric is correctly hooped, the bobbin is correctly wound and securely in the bobbin case, try loosening the upper thread tension by two clicks and see if that helps the problem to go away. (SET menu, numbers and plus and minus signs under the icon that looks like a DNA thread - minus to decrease tension.)
Jun 04, 2009 | Husqvarna Designer I
I have a designer 1 that won't release the bobbin.
Winding too tight;
Whenever your bobbin won’t come off any Viking, Designer 1 included, it’s because it wound too tight. This is how you know. It went on easy! To get it off, don’t pry, slowly unwind all thread, it will change shapes and let go of the bobbin winder. My favorite way to wind a bobbin on a Viking is to thread the machine through the needle and go under the foot then up to the bobbin winder (it has to be under the foot or it winds too tight. If it still winds too tight, lay your thread down instead of standing it up, the weight of the thread can increase tension on the winding process also check that you use a spool cap as large as or slightly larger than your spool. If it still winds tight. I’ll explain what bad thread can do.
Test your thread quality to start, thread your machine and LIFT the presser foot (this opens the tension disks). Pull your top thread straight back. If you feel no tension no mater how much thread you pull, your thread is good. If that your machine passes that test (tip: always check your thread this way when you thread your machine)
Mar 12, 2009 | Husqvarna Designer I
Singer 750 how to rewind the bobbing?
1. Push in indent (illustration 1) on hand wheel disc. This will stop the needle from moving.
2. Place spool of thread on spool pin.
3. Slide spool pin holder/cap (illustration 2) firmly over rim of spool to prevent thread from tangling.
4. Lead thread passing it first through the lower slot of the thread guide. Next through the upper slot, leading the thread to the right and around (illustration 3).
5. Wind thread clockwise around front of bobbin winder tension disc (illustration 4).
7. Pass thread end, from inside, through small hole in rim of bobbin.
8. Holding thread end, step on speed controller to run machine until desired amount of thread is wound. (Winding stops automatically once bobbin is full.)
9. Cut thread; push bobbin to the left and remove it from bobbin winder pin.
10. Trim thread end from top of bobbin.
11. Press the bobbin winding indent on hand wheel to its original position. If necessary, turn hand wheel to engage needle movement.
Feb 09, 2009 | Sewing Machines
Machine embroidery
You should always use proper Bobbin Thread for embroidery - not a bobbin wound from regular dressmaking thread. You are right, the special bobbin thread is thinner so that the embroidery thread will be pulled to the underside and you get a nice shiny embroidery on top with no bobbin showing through. Wind yourself 6 or more bobbins at a time of bobbin thread to always have some on hand, or buy the pre-wound L size ones.
All embroidery machines - no matter what brand - recommend using bobbin thread for embroidery. It is readily available at all sewing stores, probably even Spotlight would carry some. If you get stuck for a supply, try overlocker thread.
Dec 04, 2007 | Husqvarna Designer I
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Marvin
Marvin
Charles Tidwell
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
