SOURCE: Mitsubishi WS-A65 Sparks coming from the Bulb Ballast
Your crt is leaking coolant onto the board , you need to rebuild whichever crt's are leaking and fix the board!
SOURCE: Need to replace the ballast on a 52HM94
the ballast is a small rectangular board.it is very easy to change.remove the lamp and you
will see a plug where the lamp plugs into.remove the two screws on that plug.then
remove the 4 screws holding the ballast in.remove the ballast and install the new one.
SOURCE: KDS-60A2020 Sound works, screen goes black, green light blinks
Could be the lamp is failing.
Testimonial: "Thanks for the advice! I'll buy a bulb and see if that fixes the problem! Thanks again!"
