S#8010TR0026 M# SCFHD250GNC Gas Fryer turns on dashboard saying CYCLE and HELP with a decimal after H meaning ignitor is on...The drain is closed and I have pressed red reset button but still not working and still beeping and showing H.ELP code...
SOURCE: gf 40 frymaster fryer
Hi, I am suposing that this fryer has worked good in this location before. If not, check to make sure it is set up right for your gas supply. (LP-Nat) There is something wrong with the gas - air flow in your unit. Look for obvious things first like exhaust being blocked, Flame dancing out side of fire area, Pilot too small, Build up of debris in fire box. The pilot should be able to be adjusted at the gas valve if it is too small. I believe you problem could be taken care of best with a good cleaning of the burner, fire box and pilot assemble. Make sure that all burner holes are clean especially around the pilot light. Check for oily debris inside the fire box to make sure its not leaking into the fire area. If you are unable to do this yourself, contact some one either in the restaurant equipment service business or heating and air conditioning business. Hope I have helped you. kstfas NOTE: If this answer does not rate at least 4 marks, (almost there) please do not rate. Thank You.
SOURCE: please help
the the safety its pretty common on deep fryers with out that man i would be in trouble i leave mine on sometimes so its not a bad thing
SOURCE: Frymaster Pilot not lighting
first thing I would check is to make sure the quick disconect on the gas hose is fully connected,and that the cut off valve is tured on.Sometimes the orifice in the pikot assembly can become stopped up.(where you light it by the burner)you can check there by undoing the gas line at the compression nut on the assembly.the hole is really small and you can use a small needle to clear it.
SOURCE: Dean #SR142GN fryer want to convert to LP Can we
give me a shout at [email protected]
I have the part #'s you need & prices and would be able to get that out to you asap.
captrick
