Question about Numatic Vacuums
Edward hoover my Edward hoover has suddenly jus stopped working why could this be have changed fuse
Posted by Julie Wheatley Was... on
Custom Exchange
  • 397 Answers
If you changed fused, check power cord voltage or switch
Posted on Feb 28, 2014
1 Related Answer
Roger Potts
  • 694 Answers
SOURCE: using hoover, stopped working.
Give the vacuum time to coold\ down, then try again. If it still doesn't work, take it to a repair shop to be checked.
When a vacuum is used for long after the bag is full, the motor can overheat to the extent that the motor burns out. This is one of the benefits of having a vacuum that shuts off when the bag is full.
You should also check the hose for clogs. Disconnect at both ends and drop a coin in one end. If it fails to fall through, there's a clog that needs removed. This is likely to happen at the canister end when the bag gets too full.
Posted on Apr 04, 2011
I have a Hoover wind tunnel that suddenly stopped working when the cannister got full. Once emptied still would not start. Anything to fix this? Does it have an automatic shut off when full?
If the airflow is restricted the motor will overheat. Most vacuums have a thermal heat sensor built into the motor which will shut the motor off until it cools down.
Jan 05, 2017 | Hoover Vacuums
My Hoover wind tunnel self propelled vacuum #U6439-900 stop working. I checked the bag,filters,clean the roller and it's still not working.
Your motor may have siezed. You may have a cut in the cord somewhere too. Need more specifics to pinpoint problem. Did it stop working suddenly? Did it smoke of smell funny the last time it worked?
Nov 16, 2016 | Hoover Vacuums
Dyson handheld works for 30 seconds the cuts out
Hi Edward, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson handheld. In order to help further, we would need some additional information about your particular machine, including which Dyson handheld model you own. It would also be beneficial for us to talk you through some quick diagnostic checks when you have your machine fully charged and easily to hand. We should then be able to help you determine which part is at fault.
At your earliest convenience, please give our experts a call - you can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Feb 03, 2015 | Dyson Vacuums
Is there a reset button on the hoover tempo widepath. I plugged it in and the on/off switch was ON, it sparked at the wall and then stopped working. Will not turn on at any wall plug in. Hoping it needs to...
canot see any mention of reset swich in manual, try renuing the fuse first, if it still does not work change the plug.cutting the cord back about 3 inches,if still no luck have it looiked at by your local repair shop.
Aug 01, 2011 | Hoover Tempo Widepath Upright Vacuum -...
I was vacuuming with my Hoover Windtunnel Rewind t-series, and the vacuum simply stopped working. I plugged it into other outlets all around the house but no power suddenly.
Wait 30 minutes and try again, there is a thermal overload switch that resets itself.
Clean all three filters and see what happens.
Gary
Feb 23, 2011 | Hoover Vacuums
Hoover Alyx 2000w, no power. Help!??
Its a possibility then that if the fuse has been replaced that the cable inside has either come apart or you have a broken switch. If its only a year then you should be covered automatically with Hoover's guarantee.
Mar 05, 2009 | Hoover F5411 SteamVac Jr. Canister Vacuum
Suddenly the automatic deterent mixing system in my hoover steamvac widepath (model F7443-940) stopped from working. It does not dispense detergent anymore. What could the problem be?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766252
Generic problem for all Vacuums
Suddenly the automatic detergent mixing
Posted by btaha on Jul 10, 2008
Suddenly the automatic detergent mixing system in my Hoover SteamVac WidePath (model F7443-940) stopped from working. It does not dispense detergent anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It could be the trigger assm could be broken and is not releasing the solution and or water, or the valve under the water solution tank is not releasing the solution. Please check with your owners manual in the trouble shooting manual or if you do not have a manual, call the Hoover factory cust serv and give them the brand name and model # so that they can send you a new owner’s manual. Your local vacuum cleaner dealer should be able to do a diagnosis of the problem and can give you and est of the repair. Or if the vacuum is less than one year it should be covered under the Hoover factory warranty. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Vacuums Logo
113 people viewed this question
Top Numatic Vacuums Experts
Marvin
Marvin
Are you a Numatic Vacuum Expert? Answer questions, earn points and help others
