Question about Samsung LN Televison & Video
Half of me samsung lcd TV screen is shadowed with light streak going across top of screen
Le46a557p2f model number
Posted by Liam Anslow on
  • Liam Anslow
    Liam Anslow Feb 26, 2014
    this is what the screen looks like
gemagm
    Master:
  • Samsung Master
  • 689 Answers
Sounds like the LCD Panel, if under warranty contact Samsung warranty for service. If out of warranty, watch it until you tire of it then replace the unit as the cost of a new panel is more than a new unit.
Posted on Jan 03, 2015
5 Related Answers
Anonymous
  • 58 Answers
SOURCE: LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Posted on Apr 02, 2008
Anonymous
SOURCE: dark shadow on lcd tv
u need to replace the tv backlight. it can be done by urself but its kinda complicated its better to just tak eit in to a repair man. shouldnt be that costly.
Posted on Jun 13, 2009
tvtek
Duke
  • 1284 Answers
SOURCE: shadow on lcd tv screen
A shadow of any kind showing up on a LCD TV is going to be a defective LCD panel. If not under warranty your replacement cost for the panel (if available) will far exceed replacing the TV with a new one.
Posted on Jul 23, 2009
Anonymous
SOURCE: Dark shadow-like vertical streaks thru LCD screen (Sharp)
Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
Posted on Oct 26, 2009
Anonymous
SOURCE: Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Posted on Dec 15, 2009
Samsung TV thick black line running across the bottom.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 08, 2016 | Samsung PN51E450 - 51" Class 50.73...
Model UN65F6400AF. Why is there a dark shadow across the bottom half of the screen?
This is a fault that affects many LCD screens usually nothing can be done apart from replacing the screen
Mar 24, 2016 | Samsung Televison & Video
Shadows on monitior
This sometimes occurs when the machine gets too hot. If your graphics card is too hot, its performance will suffer. Check the fan speeds/ temperatures and see if that helps.
Dec 12, 2012 | Samsung 22" TFT SYNCMASTER P2250 LCD...
Samsung TV Screen faulty
t con board failed if its half and half. can also be a lose cable on the screen to the tcon board from the lcd screen side. Tcon is in the middle off the screen on the back.
Nov 18, 2012 | Samsung LE46M51B 46 in. LCD Television
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
43'' SAMSONG FLAT SCREEN. SHADOWS RADOMLY APPEAR
Is your tv a plasma tv or an lcd tv? When you say shadow, do yo mean a band across or down the screen, or is it a patchy shadow?
Mar 17, 2010 | Televison & Video
My question concerns a Toshiba Regza model 52HL167 which displays a perfectly normal picture on the right half of the screen and a blurred and streaked image on the left half of the screen. The lcd...
This will most likely be down to your screen controller board, Take the back of the tv and look towards the top middle, You will see your screen cable go into a rectangular board this is sometimes covered by a metal plate, remove this and check Ebay or Google for a replacement, there will be a part number on the board
Hope this helps?
Mar 05, 2010 | Toshiba 52HL167 52 in. LCD HDTV
Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
Vertical line and shadowing on samsung 32"lcd tv
Clean the connectors from the main to the Tcon along with the flat cables that go to the panel, next would be repalce the tcon board,if that doesn't fix it you may have a bad panel
Dec 28, 2017 | Samsung 32 in. LCD Monitor TV
Samsung LCD television screen fault
My new TV LCD Samsung LC32C530 Series 5 has one half darker and with less contrast than the other.This is noticeable now always. There is a distinct and clear division down exactly half the display which separates the dark and light sides.. Any ideas?Thank you.
Jul 08, 2008 | Televison & Video
Televison & Video Logo
225 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Demonic-2011
Demonic-2011
