Cameras Logo
Question about Sony Cameras
LCD shows display, touch does not work
Sony DCR-HD26. LCD screen is lit, but touch interface does not work. Have tried calibration as instructed in manual to no avail. Have also tried reset. This set the clock back, etc., but I still can't get the touch screen to work. Touch screen is only way to play, fast forward, etc.
Posted by Jim Koziol on
5 Related Answers
Anonymous
  • 169 Answers
SOURCE: Touch Screen not responding to Touch
the flexwire cable is have an openline and that line is connected to the touch screen panel...it have to repaired or replace that flexwire to the service center....in our shop we modified that wire and became more durable than the original wire......:-)
Posted on Sep 02, 2007
Anonymous
  • 4402 Answers
SOURCE: Touch Screen on Sony DCR-HC32 Camcorder Does Not Work
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Posted on Mar 17, 2008
Anonymous
  • 9 Answers
SOURCE: Handycam DCR-HC21: LCD touch keys does not work
try alamocamera.com for repairs
Posted on Jul 30, 2009
Anonymous
  • 7 Answers
SOURCE: Sony DCR-HC18e Touch screen stopped
The problem you have on your Handycam is the flex cable FP-835.
You have to open the camera and change the cable.
It´s very easy to change.
Posted on Nov 19, 2009
larry james
Larry Stiles
  • 301 Answers
SOURCE: I have a sony handycam and I cannot calibrate my
The touch screens in these can shift. Can you rotate the screen and get the screen to work? if so it's possible if your skilled to recenter the screen then resecure it. of course you might end up having to replace it. I have replaced more of them than recentering them . Larry's Electronics [email protected]
Posted on Apr 24, 2010
9helpful
2answers
Sony dcr-hc26 touch screen does not work
If the touch screen of the Camcorder is not working, pleasefollow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button behind the LCD panel.
dcrhc26%20reset%20button.jpgdcrhc26%20reset%20button.jpgmoz-screenshot.pngmoz-screenshot-1.pngrsshajan_3.jpg
Note: 8 represents the reset button on the above figure.
If the issue persists again, please perform LCD screen Calibration and check ifthat helps.
Please follow the steps below to perform the LCD Calibration
If the issue persists again, service is required.
I hope this information will help you to resolve the touch screen issue of theCamcorder.
Touch screen no longer works on Sony DCR HC26
Note: In the above picture, 8 represents the reset button.
Perform a power resetting of the Camcorder. To perform power resetting, pleaseremove the battery pack, turn the Power switch to Play/EDIT/ON for more than 15seconds, turn the Power switch to OFF position and then reinsert the batterypack.
If the issue persists even after performing all the above-mentioned steps,service is required.
I reset my Sony DCR-HC21 and now the LCD screen doesn't respond to my touch. It's just stuck on the date/time screen. I tried to do the calibration, per the user manuel, but I can't get to the calibration...
there is a problum in side the camera one is ffc whicis connect the lcd to main board if no then lcd it self having problum because thes tuch switches are in side the lcd please go to your nearst sony service centre & fix this problum
1helpful
5helpful
2answers
DCR-HC40 LCD works, but Touchscreen doesn't. I was able to calibrate once -- but din't hold settings. I cannot calibrate.
hello its ruttine problem ,just change the lcd FLAP and you can use the touchscreen.its not to wory about that
3answers
The touch screen is not working. After resetting
If the buttons on the touch-panel LCD screen do not respond correctly or do not work at all, adjust the LCD screen calibration. Consult the instruction manual if specific information is required to perform this procedure.
NOTE: The touch-panel LCD screen cannot be calibrated if it is rotated.
3helpful
Connecting wire/ cable between LCD and Main Board is broken/ cracked and needs to be replace. Contact nearest Sony Service Center for proper repair.
9helpful
4answers
LCD touch screen
Take off the screws at the left side of the lcd screen, than open gently the case. Use a air can than spray for cleaning. The lcd screen is now back on duty...
Top Sony Cameras Experts
W.L.
matt
matt
Darran Hatten
Are you a Sony Camera Expert? Answer questions, earn points and help others
