Question about Radio Shack TRC-521 CB Radio
TRC520 CB wont power up
I can connect all the power wire to the fuse and ground out the ground wire. but it still will not turn on.
Posted by cowboypimp11 on
  • cowboypimp11 Jun 13, 2009
    well the radio itself i didnt buy it i got it for free from my buddy and i think he fried it cuz it dont work at all
Anonymous
    Genius:
  • 1,139 Answers
Hello, First of all you only have the Power wire Red, and the ground wire Black to connect for 12v DC to power the unit. If you memory power it is usually connected to a constant power source such as the cigarette lighter or continuous 12V dc powersupply off of the battery. These are the only connections that should be connected to provide power. Since the unit will not turn on I suspect that the CB's power supply and regulator have been blown. Another possible choice is that the radio was working and someone removed the antenna cable and the the RF power amplifier malfunctioned taking the power supply and regulator with it. To solve this problem, check the voltages on the wires before connecting them to the radio (these should be the 12 volt power off of the radio circuit, and the 12 volt power off of the continuous 12V connector (or the cigarette lighter). These voltages should read 12V. Connect the CB with it turned off and measure the voltages (should be 12V) Turn the radio on and check the voltages (should be a little less than 12V) If the radio does not come on then the internal power supply of the radio might be defective (In this case I would advise taking the CB to a qualified radio repair shop) I hope this helps Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Posted on Jun 11, 2009
thndr143
    New Friend:
  • 141 Answers
If it isnt the fuse, it is the protector diode inside the radio
Posted on Jan 30, 2010
No power to left rear turn/ brake light
Check the display. Ask a helper to step on the brake pedal while you check the lights from the rear. If no lights appear, check the fuse that connects the brake lights. The owners manual will show the location of the fuse box and which fuse is for the brake lights. Pull out the fuse and look at the wire in the central window. If the wire is broken, replace the fuse. Make sure the new fuse is not blown, and carries the same amperage.
Take note of lights that are out, if any are working. The problem may be cured by replacing the bulb in a brake light that's out. A burned out bulb has a broken filament and a dark brown spot on one side. Check the owners manual for bulb type.
Check the circuit if replacement bulbs and fuses do not restore the lights. Find the wiring diagram in the vehicle assembly manual. The circuit for the brake lights runs from the battery to the fuse, to the pedal switch, to a connection plug, to the lights. The circuit has to be checked with a volt tester at all points.
Check the battery power and the light on your volt tester. Turn the ignition key far enough to activate the electrical systems. Turn on the lights to check for battery power. If the battery has power, ues it to check the volt tester. Put the black lead (the ground) from the volt tester on the negative battery terminal. Briefly touch the red tester light on the positive terminal. The light on the volt tester should flash brightly.
Test the wiring to the fuse. Clip the ground wire to solid metal near the fuse. Touch the light tip to both sides of the fuse. Both should light the tester. If neither side lights, the wire between the battery and fuse is bad. If only one side lights, the fuse is blown.
Test the switch and wiring. Touch the light tip of the tester to both terminals on the brake pedal switch without putting any pressure on the pedal. One should carry power and the other should not. When both show power, the switch is stuck and the brake lights are always on. If neither shows power, the wiring between the fuse and the switch is bad. Now check both switch terminals while the pedal is depressed. Both sides should light the tester. If not, the switch is bad.
Check the connection plug. Unplug the connection and refer to the vehicle manual to identify the brake light wire. Touch the tester light on the brake light wire at the inner socket on the battery side. If the tester lights, the power is flowing to this point. If not, the wire between the plug and the pedal switch is bad.
Check the socket. Plug in the connector plug and remove the bulb. Touch the contact inside the socket. If the tester lights, the socket is good. The socket and wire running to the plug should be replaced if the tester doesn't light.
Check the bulb with the ground wire. The bulb must be in its socket. The ground wire running to the socket should be black or brown. Stab the tester through the insulation. If the tester lights, the bulb is good. Replace the bulb if it doesn't light.
Check the ground wire. Remove some of the insulation around the ground wire. Twist one end of the extra wire around the exposed ground wire. Touch the other end to a solid piece of metal. If the brake light comes on, the ground wire is bad.
Best Offer 2013 11 MB SD Connect Compact C4 Star Diagnosis with WiFi
Oct 13, 2014 | 2000 Ford Expedition
Power turned on yesterday but now doesn't work. I didn't alter the power source.
First of all, find out whether that ground wire is fastened to metal. Next, with the RCA cables disconnected, try to get the amplifier to turn on. If no luck, could there be a fuse for the Kicker that may have blown? Finally, go back over the installation. A connection may be failed or grounded.
Nov 17, 2013 | Kicker 2011/11 Hs8 Car Audio 8"hideaway...
My 96 Toyota Camrys windows don't go down or the
You need to see a wiring diagram to see how the ignition switch allows or sends power to that 30 amp fuse. The switch may turn on a relay (maybe the ignition relay) that sends power to the fuse panel. Or the run wire out of the switch may itself turn power on at the fuses. You may have a loose connection behind the fuse panel.
Get a test light, pull the fuse, and check for power at the fuse terminals, with key on. One terminal for the fuse should have power. If not, power is lost between the ignition switch and that fuse. If it does have power, and windows still don't work, check the wire from fuse panel to the master switch-loose or poor connections, maybe a partially broken wire. If it looks good, check the ground wire for the windows. The ground wire originates at the master switch and will go back into the cabin to a nearby ground, possibly behind the left kick panel. If still no help, someone may need a volt- ohmmeter to start checking continuity of wires, voltage drops, etc.
Jun 18, 2013 | Cars & Trucks
Car stereo wired to battery and fuse box what wires go where
If this is an aftermarket stereo, The red wire needs to go to a power source that turns on and off when you turn your key on and off ( a fuse in the fuse box ). The yellow wire needs to have power all the time like its connected to the positive battery terminal or a fuse in the fuse box that always has power and the black wire is the ground and needs to be grounded to the negative battery terminal.
Oct 22, 2012 | Alpine TDA-7563 Cassette Player
I have a 2004 GMC Sierra 2500HD and ever since ive had the truck ive had trailer light problems. The problem I have is I dont have running lights and the right side brake and turn signal do not work. I...
Check the plug wiring again on the truck. You have a wire crossed , when you hit the lights and it only blows with the trailer, then there is a crossed wire on the truck. What seems to be happening is your sending power to the ground for the trailer. You can check the trailers ground with an ohm meter, then make sure your truck ground matches that pin. You may know this , but green rght turn, yellow is left turn, brown is parking lights, black is brake lights, and white is ground.
Aug 05, 2011 | GMC Sierra 2500HD Cars & Trucks
I have good power and ground connections but the amp will not turn on.
Make sure the fuses aren't blown. There should be fuses on the amp itself and an in-line fuse in the live power wire near the car battery. If the fuses aren't blown, make sure the remote wire is connected from the head unit. Then re-check your power and ground connections. The ground should be solidly connected to the vehicle chassis in a paint-free location.
Feb 23, 2011 | Visonik VB212PKG Car Audio Amplifier
Hello, the name's Jordan The Product: Pioneer Avid D3 Navigation system. Here's my problem: The screen will not come on. I have already attempted to hit the reset button, and still nothing. My...
Sounds like a power issue. If you don't have power on both the constant and the switched ignition wires for the head unit you'll usually end up getting the little LED light on the unit so it looks like it should be working ok but the screen won't turn on and the unit won't work. If you can take the head unit out yourself and access the wires behind it then here's a simple walk thru that you can use to pin point the issue.
First things first, before taking the time to remove the head unit, check your fuses in the car fuse block. If your fuse box cover doesn't give a description for each fuse, then look in the owner's manual for the car. (flip to the very back index under "F" and it will have a page number for "fuses". The first one to check will be the Radio fuse. If this one is ok, then also look at the following:
Accessory, cig lighter, instrument cluster, interior lights/domelights, audio, and amplifier. Not all cars have the same fuses and names, so just look thru the descriptions carefully and use your best judgement. In some vehicles the radio actually shares a power circuit with the things I just listed above, even though you wouldn't think it makes much sense. Also, keep in mind that most cars have multiple fuse box locations so if you don't see it on the interior fuse box, be sure to check the underhood fuse box too. Some cars will have a fuse box under the driver's side dash, another on the passenger side, another under the hood, and some cars even have them in the trunk or under the back seat.
If all these fuses check out ok then you'll need to dig a little deeper. Here's where you'll need to pull the head unit out of the dash and access the wiring. If you unplug the main radio harness from the back of the Pioneer you'll notice that there's a fuse here as well. They're usually a red, 10 amp mini ATC fuse. If this fuse is ok then continue on.
In order for a radio to turn on and work you need to have 3 wires connected properly. With just these 3 the unit will turn on and act just the way it should but you wouldn't hear any sound without the speaker wires being connected etc.
The 3 main wires are Power (aka 12+ or battery), Switched Ignition, and Ground. The Power wire is YELLOW and is considered a constant power wire. This feeds just enough power to the radio at all times to retain audio settings, radio channel favorites/presets, the clock and so on without killing your car battery.
Switched ignition is the RED and this wire only provides power when the key is turned on. Technically you can wire both the red and yellow wire to ignition only or constant/battery only but then every time you turned the car off you'd have to set all your favorites again, redo your audio settings and reset your clock OR if you wired them both up to constant instead your radio would stay on even when you turn the key off and you'd come out to dead battery every morning.
The ground wire is BLACK. This should be either connected to a ground wire in the radio harness, or if the specific car side radio harness doesn't have a ground wire, you could also connect this wire straight to metal inside the car.
If all the fuses are still good in the car using a voltmeter or multi-meter with a voltage setting and put the black terminal lead on the BLACK ground wire and the other terminal lead (usually red) on the YELLOW constant wire first. With the key turned off you should see anywhere from about 11 to about 13 volts. If you do, that's good. If not, you have a fuse blown somewhere in the car or a bad connection on this wire between the car harness and your radio harness.
Now, keeping the black lead on the ground wire, put the other lead on the RED Switched Ignition wire. With the key turned off thise should read at 0 volts, now turn the key on and you should get again somewhere between 11 and 13 volts. If you don't have power in this wire with the key turned on then again you have a blown fuse somewhere that you missed or a bad connection between the car and radio.
IF you didn't get any power on EITHER wire with either the key on OR off then you probably have a
bad ground connection. Put the black lead from your meter onto bare metal and repeat the last steps with the YELLOW and RED wires. If you get voltage now like you should have in the above steps then you know you have a bad ground connection between the car and the radio. Double check the ground connection or just attach the black wire from the Pioneer directly to bare metal in the car. Good luck
Dec 01, 2010 | Pioneer AVIC-D3 Car DVD Player
KAC-8104D Car Audio Amplifier: Fuse keeps blowing why...
Most likely a bad ground connection, clean up where the ground is connected to the vehicle, check the power wire connections too, if that doesn't help route the ground wire to either the chassis or the battery to get a lot better connection, also possibly if you have the amp on full gain (max power) it may be getting a surge from your vehicle which means turn to down a little or get a capacitor.
May 16, 2010 | Kenwood KAC-8104D Car Audio Amplifier
Power/ Ground Problem. Im running a 6ga Power wire to the battery (approx 6')with a 40amp fuse. The amp turns on, then about 10 seconds later blows the fuse. The ground is the same ga wire and is grounded...
1. Start by undoing your ground.
2. Use a jumper cable to hook up the ground to the battery ground.
3. Install fuse and test.
If it continues to blow you have an internal amp problem.
If it fails to blow a fuse you have a problem with the chassis ground.
If it is a ground issue you can chase down the various ground straps and clean the connections or you can run another ground cable to the chassis (body) ground to the battery to reestablish the connection.
Feb 10, 2010 | Rockford Fosgate Punch 201S Car Audio...
Stero not coming on
What kind of car do you have? This can make the difference. Many cars with small engines (eg. Geo Metro) simply do not generate enough power to operate the radio. Other times the car can generate enough power to support the radio, but when you plug something into the cigarette lighter/power outlet the radio shuts off because the car isn't powerful enough to handle both. The first thing you need to do is to make sure that the car's electrical output is sufficient to operate the radio, after that it would be a good idea to make sure that all of the wires are connected properly.
Oct 29, 2008 | Pioneer KEH-P4020 Cassette Player
Radio Shack TRC-521 CB Radio Logo
376 people viewed this question
Top Radio Shack Radio Communications Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
