It will scan i have 3 numbers wont scan it act lke the numbers are stuck scanner will say anything what should i do to fix it
SOURCE: scanner wont scan
provided you turned the squelch know and it didnt help, i would trace back from the squelch control to the first and second transistor you come to and that should be the squelch circuit. if you know how to check them with an ohm meter you can find out which one it is, if not you can just replace them both for under 5 bucks.
SOURCE: acts like squelch is stuck
I had the same problem. Your board may be fried. I had to buy a new unit.
SOURCE: Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
