Clymer Mercury/Mariner 2.5-60 HP Two-Stroke Outboards Includes Jet Drive Models 1994-1997 Logo
s
sias swart Posted on Feb 24, 2014
Tuneup specifications for mariner 60hp outboard motor please
I need tune-up spesifications mariner 60hp for carb tuning and ignition timing as well. my engine serial no. 6497701
How to drain carb bowls on 1999 mercury 2strock 3cyl 60hp outboard
Hey Geoff,,, there is a "bolt" on the side of the float bowl,, unscrew and remove it,, gas should flow out, freely.,,while the "bolt" is out.. pump the bulb and this will help flush out some crud..BUT - For a complete cleaning,.. you need a qualified professional... its #25 on the diagram Parts for Mercury Marine 60 HP Bigfoot 3 Cylinder Carburetor
6fos 000292
only numbers matching yrs are a 60hp mariner 1983.
1helpful
Carburetor adjustment zama walbro tuneup
Too long to print here. Go to the zama web sit and they give you a wonderful procedure for adjusting a zama carburetor. Especially important after you have taken it apart and installed a new carb kit. And even if you get a new carb the initial settings are so called defaults and you should really fine tune the carb for your specific motor.
Merc outboard 115HP 1996 fuel primer/Choke
Hello there
here is a good place to start ok Outboard (wiring A Tachometer To An Outboard, Mercury Outboard Float) safe.gif
merc outboard motors mercury outboard ... diagram of mariner outboard motors johnson outboard fuel problems ... johnson outboard motors ebay 1996 115 hp mariner outboard
  • tipsterdatabase.com/mods.php?id=outboard
  • · Cached page
Aug 27, 2009 • Boating
4helpful
2answers
1974 60hp johnson outboard won't run on full throttle under load , max 10%. New fuel and filters ect. The motor is old but has very low hours.
Carbs probably need to be cleaned and re-built. Common problem in outboards that havent been run in a while
Apr 12, 2009 • Boating
1helpful
Tune up specs for honda outboard
You have probably already found an answer, but all the specs are in the owners manual. If you do not have one, you can download one for free from honda-marine.com under the owners section. You will only need the serial number for your engine.
5helpful
2answers
What is the correct fuel/oil mix for evinrude 4hp ?
the proper mix is 50 to 1 or 16 oz to every 6 gallons,in my little boat I put 4 quarts in the 48 gal tank and its been running for 22 years,your running way to rich and your plug is probaly fouled,take it out clean it up/dump your fuel and mix it right,thats a great motor you got,I hunted with it for years,oh yeah when you get started run it till all the smoke is gone or you will have carb problems ,if you dont have them all ready,a little carb cleaner wont hurt but get it running first,or all that trash will foul you out,have a great trip bartriley1
Jan 04, 2009 • Boating
Top Clymer Boating Experts
john h
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Clymer Boating Expert? Answer questions, earn points and help others
