Olympus FE-210 Digital Camera Logo
Posted on Jun 11, 2009
I have an Olympus FE-230 and it suddenly starts taking black and white pictures. I don't know what I did, but how can I get color back?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 13, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
219
Points
I have had my Olympus FE-210 for about 2 1/2 years just recently it started to display an all black screen after I took pictures and like many of you I would turn it off and back on just to get 1 picture out. After testing it over and again I may have solved the problem: First: remove all of the pictures and memory card from the camera Second: go into the menu and find the reset button it will then display that the camera will return to default(factory setting) after I did this I was able to take over 35 continuous pictures using every setting and scene setting the camera has If this doesn't work I would suggest buying a new camera Hopes this helps!!
Anonymous
Level 1:
Problem Solver:
  • Contributor 18 Answers
  • Posted on Jun 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
18
Questions
0
Helped
6634
Points
60
Try Olympus' web site for technical support.
1helpful
Can we take black and white pictures with this camera olympus fe 310
No. However, any photo editing program can convert a color picture to a black-and-white picture. Doing so on a computer gives you much more control over factors like contrast and brightness than a camera can.
1helpful
Can I change the color of pictures to black and white? If so, how?
The FE-230 doesn't have a black&white mode. However, just about any photo editing program will give you the capability of converting color pictures to black&white. Doing so on a computer also gives you much more control over things like brightness and color.
2answers
Problem with my Olympus FE-230
When I turn my camera on, the lens goes in and out a few times. Once it's finally on and I look at the screen, everything is blurry. When I take the picture, it's blurry too. If I try to use the zoom to adjust, the lens starts going in and out all crazy and won't adjust right.
We have an Olympus FE-230. When the camera is
It's possible this is a repair issue with the LCD screen of the camera especially if you are able to review previous images but cannot take any new images. You may want to call Customer Service to discuss repair options. Their telephone number is 800-622-6372 option 2 and then option 3.
My olympus fe 230 freezes up when looking at photos on the camera
check battery compartment... may not be making good contact
Blurry Pics
Hi taataa (cute name)
Does the lens seem to come all the way out, and does it move, in and out, when you turn the zoom control back and forth ? let me know and we'll go from there.
Regards, Paul
My camera
check the battery to make sure it is making good connection
Cant take picture
The lens assembly and or microprocessor has failed.
Contact Olympus
Good luck, Paul
Olympus fe 230 Black spot in screen
Something has probably got inside the lens,
2helpful
Flash not working
The flash tube or the circuit could be burned out as it is fairly high voltage.
if the tube is black then its blown
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
