EA - Electronic Arts The Sims Double Deluxe for Windows Logo
Posted on Jun 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Trying to register disc 4 sims and keeps sayin invalid code
Typed in code numerous times. and keeps sayin code is invalid. typing code from the manual/case
need help. thank you
Cheri
marley mcelhinney
Level 3:
  • Master 490 Answers
  • Posted on Jun 12, 2009
marley mcelhinney
Master
Level 3:
Answers
490
Questions
31
Helped
186075
Points
1178
Ok if the code on the box doesn't work you can download a free program called keyfinder you can get them off freeware sites, it will reveal the key for the game it takes a bit of playing around to figure out how to use the program but its not tricky
My E5 keeps sayin invalid sim
It the Phones says invalid Sim card means it locked to Network you need to unlock it from the network lock,you can get the network unlock code from here
Mobile-unlocker.com and unlock it from Network lock,then you can use with any GSM Network Sim card in the Phone.....You need to find the network and country it locked now and specify that to get the unlock code....
My "myphone qw29duo keeps on
Hi babybanchi,
Have a nice day.
Invalid Sim usually occurs when the mobile is locked to a particular network.To solve this you should unlock your mobile using software,cable and codes.Unlocking mobile using codes seems to be simple compared to other ways because it saves our time and money. There are numerous online sites that caters unlocking codes.
You can run this link for further understading:http://www.onlinegsmunlock.com/motorola-
a1000/rs7wp9/
Form here you have to select the model of your mobile and the country provider to which your mobile get locked and get the unlock codes from them.
Hope it helps.
Thank you for using fixya.
Adieh
Sep 16, 2011 • Cell Phones
1helpful
2answers
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Please rate me and give testimonials if ever to continue my assistance
lg-phones
I tried making a pin code for my lg GU29of model and it asked me what the default one is i typed what it said and it kept saying invalid pin after saying invalid a few times it switched me to puk code and...
Your PUK is listed on your account. You can call your customer service and they should be glad to provide that for you.
AT&T allows you to check that yourself if you log into your account online.
It's a rather long number so make sure you can see it clearly, or write it down before you sit down to type it in. NOTE: You only have 10 attempts to enter the PUK before it will lock your SIM permanently and you'll need to purchase another SIM to replace it.
Before trying the PUK (which is a PIN Unblocking Key), power your phone off and then back on. Then enter the PUK. Once you enter the correct code it'll ask you to enter a NEW PIN. Remember that one as that will be your new PIN.
If you get it wrong enough times it'll go to the PUK again.
Dec 18, 2010 • Cell Phones
2answers
Invalid sim card has been working now i changes it out and it states invalid sim
Remove the SIM card and re start the BB with new SIM card.
Your sim card is not proper fitted . check the sim setup
http://www.o2.co.uk/deviceinfo/device-pdfs/rimblackberry9000eng.pdf
1helpful
2answers
My cell phone says invalid sim card
Your BlackBerry need to be unlocked .
It's a full detailled guide on how to unlock your BlackBerry .
please read it carefully .
1. Insert any sim card
2. Turn off all of the wireless connections
3. Go to Options
4. Select Advanced Options
5. Select SIM Card
6. Hit menu select show keyboard (where needed)
7. Type MEPD (you will not be able to see the typed info)
8. Type MEP2
9. Now it will say enter network mep code
10. Enter Unlock Code
All done. I suggest you by the unlock code from a fast and reliable codes seller such as blackberrymep.com .
4answers
Sim card invalid. what do i do (balck beery pearl 8100)
it needs an unlock code. you may have to purchase one or ask your provider for one. the procedure on how to enter it and where to purchase it can be found here.
2answers
Invalid sim cardhas started to appear on my blackberry
if its showing that in valid sim cad
it means your phone is locked only one network.
try to do sim unlock your phone on line and you can do any phon unlocking shope
16helpful
4answers
Showing INVALID SIM
try *2767*3855# this will reset the software and unlock your phone to all network, but make sure you backup all of your photos etc before tou type this code in.....Chris
Top EA - Electronic Arts Video Game Consoles & Games Experts
ZJ Limited
ZJ Limited
Are you an EA - Electronic Arts Video Game Console and Game Expert? Answer questions, earn points and help others
