Question about Sewing Machines
How to thread a brotherxl-4040 sewing machine
How do I thread a brother sewing machine it is a xl-4040
Posted by molly polly on
Hassy
  • Sewing Machines Master
  • 1,388 Answers
5 Related Answers
Anonymous
SOURCE: Brother XL-5130 Sewing Machine
Put the thread through one of the holes. Then put the bobbin on the spindle. Pull about 3 or 4 inches out of the hole and hold on to it. Start winding the bobbin. After about ten turns, or when the winding thread is secure, you can stop the machine and cut off this 3 or 4 inch tail. To insure that the thread winds up and down the bobbin and not off the top or bottom, there is probably a metal bobbin tension disk that the thread must pass around before it goes to the bobbin. It is probably on the left of the machine and may or may not be part of a thread guide. The thread must pass around this disk on its way to the bobbin in order to put tension on the thread so it will wind properly. If you can't find the disk, which is a small metal button or screw with some type of somewhat moveable spring cap, you can just get the thread to pass through your thumb and forefinger. Hold your hand 6 or 8 inches to the left of the bobbin and pass the thread between your thumb and forefinger so that it makes the thread go in a direct straight line to the bobbin. Pinch the thread only enough to keep it taught but not tight and let it flow through your finger to the bobbin. The thread should go up and down evenly on the bobbin. If not, move your hand up or down to position it so the thread will wind up and down smoothly. It will not be necessary to move your hand once you find the correct position needed for winding.
Posted on Jul 20, 2007
Anonymous
SOURCE: BOBBIN THREAD
omyGod!! Thank you sooo much!!! I changed the tension on the top of the machine, like you said and now, it is working beautifully, God bless You!!!
sandylou
Posted on Dec 08, 2007
Anonymous
  • 27 Answers
SOURCE: Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
Anonymous
make sure that when you insert the thread *top hole bottom to top* that you turn the bobbin itself until you hear a click *that is the spring sliding into the ****.
Posted on May 02, 2009
Thirza Peevey
  • 5 Answers
SOURCE: Sewing Machine (brother XL 3200)
You may have the bobbin case in wrong.  I have this machine, and I know that it is really easy to put the bobbin case in wrong.  Try taking it out and making sure that the little stop is in the front and it is seated down in there and able to wiggle back and forth.  My experience with this machine, until the other day when my cat knocked mine off the table and knocked something out of alignment, is that it just works.  Any time mine hasn't worked, it has either been dirty, needing oil, threaded wrong or the bobbin case wasn't seated right.  In other words, it has always been my fault.
Posted on May 25, 2009
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
How to adjust the tension on a BrotherXL-3510
I'm assuming that you have used the tension dial on the top of the machine to adjust the upper thread tension and it didn't tighten the tension. The most common cause of that is your thread is either not between the tension disks, or it's only on the rim between the disks, which means you get SOME tension, but not enough.
When you thread any sewing machine of any age from any manufacturer, you MUST have the presser foot up. That is because two disks that the thread goes between and applies the tension on the upper thread, are ONLY spread to allow the thread to go between them when the presser foot is UP. While every user's manual tells you to put the presser foot up when you thread, they don't tell you why so it doesn't make any impression.
Sep 10, 2014 | Brother XL-3510 Mechanical Sewing Machine
How do I adust the tenion for a straight stitch on a BrotherXL-3510?
Set the stitch selector to straight stitching.
Set the stitch length to 2.5
Set the thread tension dial (leftmost dial) to 5.
Done
My brother XL-2230 wont actually spin round. it did, i accidently fit the power peddle, and now it wont sew/spin round??
if the machine was threaded at the time, the upper and lower threads will have jammed and now are preventing the machine from turning
Feb 17, 2014 | Brother XL-2230 Mechanical Sewing Machine
How to put the bobbin case back together on a brother xl 2600 i
I would go to a sewing machine store with it and ask them it it looks right .if I wasn't sure
Oct 10, 2012 | Brother XL-2600I
Adjust the tension
lost discs with instructions for my Brother XL sewing machine and am finding difficulty to adjust the thread tension and it is not catching the thread properly
Feb 02, 2011 | Brother XL-2600
Thread is catching & breaking somewhere inside the machine before it gets to the needle. brother XL-5600 machine
According to page 18 of the manual, the only place the thread could be catching would be the tension discs or the uptake lever.
Lift the presser foot and run a heavier thread or flat, unwaxed dental floss through the threading procedure to see if this will clean out a thread that may have jammed into the discs.
Always thread with the presser foot up and make sure the uptake lever catches the thread.
If this continues, take the machine to an authorized Brother dealer for service.
Apr 10, 2010 | Brother XL-5600 Mechanical Sewing Machine
Brother xl-2600I sewing machine thread problem
Try turning the handwheel so the take up lever is at its top position, then remove the garmet.
good luck!
Jul 30, 2009 | Sewing Machines
Sewing Machines Logo
91 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
