Question about Samsung SCX 4521F All-In-One Laser Printer
Samsung scx-4521f toner fuse resistance - Samsung SCX 4521F All-In-One Laser Printer
Posted by ata zuobie on
5 Related Answers
Anonymous
  • 3 Answers
SOURCE: Samsung SCX-4521F "no cartridge error"
In the back of the printer, after you take out the back side, there is a contact with two wire: black and red. That switch is presed by the cartridge. Or you should push more the cartridge into the printer.
Posted on May 29, 2008
Anonymous
SOURCE: Samsung SCX-5421F Laster Printer crashes my pc
Have you tried uninstalling and re-installing the software. Perhaps there is an updated driver for your system since you first installed it, or maybe yours is simply corrupted. I would suggest removing and reinstalling will solve the problem - if, in fact, that is your problem -I've not heard of this happening before.
Drivers are here if you need them:
http://www.samsung.com/ca/support/download/supportDown.do?group=printermultifunction&type=printermultifunction&subtype=monochromemultifunction&model_nm=SCX-4521F&disp_nm=SCX-4521F&language=&cate_type=all&dType=D&mType=DR&vType=&prd_ia_cd=06010300&model_cd=&menu=download
Posted on Apr 14, 2009
Anonymous
  • 76 Answers
SOURCE: New cartridge saying low toner
Try these steps:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Let me know if it doesn't work as there is another possible solution.
Posted on Sep 01, 2009
Anonymous
SOURCE: Cru fuse error on samsung scx 4521f
i changed fuse 4521F , but : (cru fuse error) ???
Posted on Apr 14, 2010
Anonymous
SOURCE: Samsung scx-4521f-How to scan multiple pages to single pdf file?
get acrobat professional, its pricy, but it workes
Posted on Nov 11, 2010
The printer samsung scx-452f cannot print out fax in,it shown on screen as memory receive
you have received faxes, but they can't be print until you replace toner because probably you have TONER EMPTY message also on the display.
You can buy only fuse for toner cartridge (25mm, 250V/ 0,063A or 0,1A and maximum 0,125A)
When you pull out toner cartridge you will see the glass fuse on the front left side of the cartridge.
The new fuse will reset toner empty condition
pifonski
Feb 28, 2011 | Samsung SCX 4521F All-In-One Laser Printer
CRU FUSE ERROR SAMSUNG
hello,
their is small fuse in your toner cartridge.you have to replace it . it is also damage.
Jan 13, 2011 | Samsung SCX 4521F All-In-One Laser Printer
How can I check toner livel
download the user manual here:
http://www.samsung.com/us/support/downloads/SCX-4521F
it does not appear that you can check the toner level, but there are several pages that deal with the toner, check it out
Jan 08, 2011 | Samsung SCX 4521F All-In-One Laser Printer
NAME OF TONER AND HOW TO REFILL
Samsung Black Toner Cartridge for SCX-4521F Part #: SCX-4521D3 samsung_scx4521d3.jpg
Its price: $76.99 You just pull outward the old print unit and replace it with the new !
Good Luck!
Dec 07, 2010 | Samsung SCX 4521F All-In-One Laser Printer
My Samsung SCX-4521F printer displays TONER LOW
It means that you will be out of toner soon and you won't be able to print.
I do recommend that you always have a spare.
pls. vote for better service
Nov 13, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Toner empty after replacing new toner of samsung scx-4521f what to do to remove this message
press menu# 1934 then display tech mode
press left arrow key and enter twice
then its ok
to go normal display continue previous simulation.
May 20, 2010 | Samsung SCX 4521F All-In-One Laser Printer
SCX-4521F All-In-One Laser Printer: toner empty after replacing new toner of samsung s...
Clear/reset the settings on the printer. Press in this order w/o pausing:
menu
193
start
If you do it correctly, the LED will say "Select Country, US", then you press "OK", then it will clear the settings and the error message should go away unless you have a dirty sensor or your toner is installed incorrectly.
Good luck-
May 18, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
56 people viewed this question
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
