There will still be something jammed in the path. You may need to lift up the paper guides to see it - even to the trained eye it can take a few minutes to spot.
on the back side of the printer is a door to access the jammed paper check out if any of the paper piece is got there already jammed and due to this other papers passing through that area are getting jammed.if that area is clear then its gear problem which pulls the paper There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced. thanks
Go to kodak.com/go/itg and follow the step by step solution on how to clear the paper jam.Take a moist cloth and rub it between the rollers on the back of the printer.If issue persists,call Kodak @ 1800 421 6699 and they will replace the printer for you free of cost for you.
try freeing up the paper before you insert it into the printer. an easy way to do this so to "fan" the paper by holding one end and letting each paper on the other end be released one by one.
another thing is that you may be inserting the paper too much inside the paper tray. try inserting the paper slowly and stop at the first slightest notch you feel
Recurring paper jams can be caused by broken parts, using too much paper in the in-tray, or parts (usually the rear door) not on all the way. This video explains how to fix a paper or carriage jam, but explains along the way the things to watch for. If you go through the steps in this video and you still get paper jammed, you may have a broken printer that needs to be replaced or repaired.
Clean the pickup rollers and ensure that there isn't a small peice of paper lodged between them. I use a product called "rubber renew", it removes the dust, dirt, etc. and eats away someof the rubber to make it rough again.
