RIM BlackBerry Storm 9530 Smartphone Logo
Anonymous Posted on Jun 11, 2009
My Send & Escape buttons wont work on my Blackberry Storm
All the sudden these two buttons stopped working this morning. The Menu & End buttons work fine. Anyone know what's up?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 12, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
310
Points
Hi Bethanyka219 or anyone,
Did you finally resolve these issue, i am having the same problem with my send and escape button. appreciate any help, you can give.
Mike
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 11, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
3172
Points
16
Try taking the battery out for about 30 seconds then turning it back on. If that doesn't work, try running on air programming if that is available to you. Check with your customer service for that.
5helpful
5answers
Free mep code for blackberry storm 9530
It is very easy to unlock Blackberry storm 9530.i did find a third party. i had unlocked mine.it work perfectly.which might help you find the cheapest solution.Have you tried your network provider for free code?
Hope this help.
5helpful
6answers
I need the MEP code for my blackberry storm to please help. is there any way i could get it for free??
1. Turn off all your wireless connections
2. Go to the Options icon on the device
3. Select Advanced Options
4. Select SIM Card
5. Hit the Menu key to select Show Keyboard
6. Enter mepd (you will not be able to see the typed info)(enter just the mepd, no spaces, etc.)
7. Enter the letters: mep2
8. Now it will say enter network mep code
9. Enter the code given you, usually about 16 digits
10. Your Storm is now unlocked.
1helpful
3answers
Mms not working on unlock 9530 storm unlock for att
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
http://blackberryimeiunlockcodes.com
1helpful
Bluetooth problem
Hello
6helpful
2answers
I cannot send pictures from my blackberry storm,
You receive a Failed to Find Service message when you attempt to transfer a media file between two BlackBerry Pearl smartphones.
The BlackBerry Pearl smartphone receiving the media file is not properly configured.
To send and receive files between two BlackBerry smartphones using Bluetooth® wireless technology, complete the following steps:
  1. Enable Bluetooth technology on the BlackBerry smartphones. For instructions, see the Turn on Bluetooth technology section of the BlackBerry User Guide.
  2. Make the BlackBerry smartphones discoverable. For instructions, see the Make your BlackBerry device discoverable section of the BlackBerry User Guide.
  3. Pair the BlackBerry smartphones. For instructions, see the Pair with a Bluetooth enabled device section of the BlackBerry User Guide.
  4. Set the Trusted field to Yes on both BlackBerry smartphones by completing the following steps:
    1. In the Bluetooth application, highlight the BlackBerry smartphone and press the Menu button.
    2. Select Device Properties.
    3. Set the Trusted field to Yes.
    4. Press the Menu button and select Save.
  5. Send and receive the transfered file.
On the recipient's BlackBerry smartphone
  1. On the Home screen of the BlackBerry smartphone, select Media.
  2. Select a media type (Music, Video, Ring Tones, Pictures).
  3. Press the Menu button and select Receive using Bluetooth. The File Transfer dialog box appears, followed by a prompt to Save or Cancel the file.
  4. Select Save to save the file to the current location, or select the folder icon to save the file in a different location.
On the sender's BlackBerry smartphone
  2. Select the same media type selected on the recipient's BlackBerry smartphone.
  3. Press the Menu button and select Send Using Bluetooth.
  4. When prompted to select a BlackBerry smartphone, select the recipient's BlackBerry smartphone.
4helpful
3answers
Dropped my storm in water :/
The best way to get any and all moisture out of the phone and out of under your screen, put it in a bowl of rice(uncooked) and it will soak up all the humidity. I did that with my blackberry and it worked awesome. However I can't get my buttons to work, I took it apart, but it is all dry.
2helpful
Blackberry Storm: My Menu button and end button do not work
This problem happened to me and I just figured out the answer. If you recently installed a new application or a new theme then it will probably mess with your button configurations. Remove the theme/application you installed just before the problem started happening. Once you removed the theme/application convert back to the default theme and your buttons should work again.
1helpful
Blackberry storm buttons wont work
Have you tried pulling the battery? Often times my Storm has locked up and nothing worked. The only way to really do a restart, is by pulling the battery.
-Take the battery out and wait 1 minute. -Replace the blackberry and wait for Operating System to startup -Test
If this doesnt fix the problem, you may have a problem unit and you should take it in to the Verizon Wireless store.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
