We each want to use a headset to Skype with another person, to help with sound problems. Do we just plug in two, or do we need a splitter? Thanks in advance
SOURCE: Microsoft LifeChat Microphone Headset Doesn't Work Properly
You should take your headset to another computer/location and see if your problem still exists.
That way you can eliminate problems with either your computer hardware or your outgoing internet connection (jitter).
I don't think that the CD will be necessary, since it is a USB device, which contains it's own little sound card and doesn't need any drivers.
If the problem persists and it turns out to be a problem with the headset, I would definitely return/exchange it.
SOURCE: Headset isn't recognized by computer and audio doesn't go through headset
With the infamous Vista, try:
Start --> Control panel --> Hardware and sound --> Sound --> Audio devices admin [I have a Spanish OS, I hope it is the same in the English version], then assign as default device the headset.
With Skype and other sw, you have to specifically pick the lx-3000 as the device that will be used as audio device (and the same has to be done to use the mic).
Pretty cumbersome....
SOURCE: broken wire to my microphone on my lifechat lx-3000
You cant wire then directly there is a USB D-A chip that controls the headset converting to 1/8" mini plugs may work one for the mic and one stereo plug for the earcups
