Water dispenser is not working
You
have two points where you can check the dispenser water. At the rear where the
water supply comes in is the water inlet valve. If you disconnect the dispenser
water line and then if the water comes out when you try the dispenser. You
should hear the valve work when you try the dispenser. If you don’t hear it
there is a dispenser actuator switch problem.
If you do hear it but water
doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of
the freezer door and try again.If it's normal here it may be frozen in the
door. If this is the case open the door till it thaws. A blanket over the
opening will prevent thawing of all the food.
