Texas Instruments TI-84 Plus Calculator Logo
Posted on Jun 10, 2009
Need comp software for ti-84 plus
I lost my cd software for my ti-84 plus and i need to insert some formulas in my calculator, any suggestions?
Anonymous
Level 1:
  • Contributor 48 Answers
  • Posted on Jun 11, 2009
Anonymous
Contributor
Level 1:
Answers
48
Questions
0
Helped
10102
Points
92
Http://education.ti.com/educationportal/sites/US/productDetail/us_ti84p.html On this link on the left hand side you have 'downloads'. You will find all the programs there.
Formulas entered onto a TI-84 CE Plus calculator. I hit the Clear button and the formulas were deleted. I did not back up the formulas on the computer. Can the formulas be restored to the calculator?
If you accidentally hit the Clear button on your TI-84 CE Plus calculator and your formulas were deleted, there is a chance that they can be restored, depending on how the calculator's memory works. Here are a few options:
  1. Memory Backup: Some TI-84 Plus CE models have a memory backup feature that saves your data even if the battery is removed. If your calculator has this feature, you may be able to restore the formulas by simply replacing the batteries.
  2. Memory Dump: Some calculators have the ability to dump the memory of the calculator onto a computer. You could try searching on the internet for a memory dump for your specific calculator model.
  3. Backup and Restore: If you have a computer with TI-Connect software you can backup and restore the data on your calculator. Make sure your calculator is connected to the computer, open TI-Connect software and select the appropriate options to Backup and Restore the data.
  4. Try a recovery software: There are some data recovery software available for the calculator, however, they might not be able to recover deleted formulas specifically.
It is important to note that these options may not guarantee the recovery of your formulas, but they may be worth trying before giving up. It is also important to make sure you backup your data regularly to prevent losing it again in the future.
Where is the '!' button on the TI 84 plus calculator?
There is no such button. The factorial function is in the probability submenu of the math menu. Press MATH left-arrow 4 to access the factorial.
Binompdf ( says n:......p:.....x:..... How can I enable this guided input on my TI-84?
In the older versions of the OS, the command binompdf( displays a command line where the user is expected to enter the arguments respecting the syntax of the command. In the more recent versions of the OS (the most recent is 2.55 MP) the user enters the input over three lines.
I suggest you upgrade the OS of your calculator to the latest version available on the education.ti.com website.
To upgrade, insert fresh AA batteries (or just good batteries), run TI connect on your computer, connect the calculator to the computer and click the update button on TI connect main screen. It will download and update the OS.
My daughter dropped her TI-84 plus. Two batteries came out. When powered on it said "ram cleared" and all her programs and manually entered formulas are gone. Apps are still there, but not...
I'm sorry to tell you that your daughter is out of luck :(
In the ti calculators, most data is stored in ram. this includes programs, variables, etc. the RAM is kept in its current state by battery power. But, when that battery power is lost the ram reverts to its normal state, erasing all data stored in it.
you best bet is going to be to re enter all data possible as fast as possible in time for testing
hope that helps :)
When i turn my calculator on it says "RAM cleared". It is then very slow . . . what is wrong and how can I fix it?
Hi yeager anna,
Since the calculator operates slowly even after the RAM has been cleared, I'd say, "Your OS must be corrupt." You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix this problem by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries when installing the new OS. If you need additional instructions your welcome to read my Ti 84 Plus solutions. I pretty much tell how you can install the new OS with another Ti 84 Plus calculator or, connecting the computer to the calculator to install the new OS. You can view my solution to install OS by clicking, "Ti 84 Plus OS installation." Just stroll down to oneplusgh's solution at that posting and, I cover a lot of topics you may need advice on to install the new OS.
If you need instructions to downloading and installing TI Connect on a XP or, Mac computer click, "TI Connect on a XP or Mac computer." I realize this posting was for a later OS but, this link will take you to the latest TI Connect software and, newest OS too. Once you get the TI Connect software installed come back to this posting and, follow the instructions above at "Ti 84 Plus OS installation."
If you need instructions to downloading and installing TI Connect on a Windows 7 computer click, "TI Connect on a Windows 7 computer." Just follow Procedure 3. You can also get instructions at this link on how to install the Ti driver to link computer and calculator. I realize this link instructions were for a Ti 89 calculator but, they will work for a Ti 84 Plus too. Once you get the TI Connect software installed come back to this posting and, follow the instructions above at "Ti 84 Plus OS installation."
My instructions is geared to save you a lot of hardship. No matter if your having to install Ti Connect or, the newest OS for your calculator. I do not use TI OSDownloader because, TI OSDownloader might not give you the newest OS for your calculator. My instructions will. If you have any questions just post a comment and, I'll respond quickly.
5helpful
My TI-84 plus silver edition calculator is not responding. Whenever I press a button it takes forever to put it up on the screen or it doesn't work at all! I need some serious help with this. I tried...
Hi purzabumafu8,
You need to re-install the Ti 84 Plus OS on both calculators, ASAP!!! You can fix these problems by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the USB or, IO link ports. Then they can send you a copy of their OS, while you receive it on your Ti 84 Plus. Hopefully, your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work. Link the two calculator together through the USB or, IO link ports with the proper cable. If don't have another reliable calculator to connect too, you'll have to connect the calculator to a computer to download the OS, goto Procedure 5. If your downloading off another calculator goto Procedure 1.
Important Note: Never disconnect a TI Connectivity Cable during a transfer. Lost of power during installation of OS will destroy your calculator.
Procedure1. Procedure to linking to another calculator.
On their calculator press, [2nd][Link][G] [Right-Arrow]. On your calculator press, [2nd] [Link] [Right-Arrow] [Enter] and, then press [ENTER] on their calculator too. Their calculator should say, "TRANSMIT" and, your's will say "Receiving." Then on both calculators once transfer is complete press, [2nd][MODE] to quit and, return to the Home screen. If the OS was transferred then your finished with these procedures. If your calculator won't turn on or, is locked up try the Procedure 2, below.
Procedure 2.
Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display
"Waiting...Please install calculator software now". If calculator did not turn on or, is still locked up goto Procedure 3, unless already did Procedure 3, then goto Procedure 4. If you calculator does come on and is responding and, your connect to another calculator goto Procedure 1. If you calculator does come on and is responding and, your connect to a computer goto Procedure 7.
Procedure 3.
Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary. Goto Procedure 2.
Procedure 4.
If the above process did not work. Try re-doing the Procedure 2, and, this time extend the time in Procedure 3, by 5 minutes to 10 minutes before you put all the batteries back in the calculator. These calculators can be a little stubborn at times so, keep trying Procedure 2.
Procedure 5.
If you can't find a calculator to connect too, you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS.
Procedure 6. Procedure to installing the latest Ti84 Plus 2.55v. MP OS. TI OSDownloader does not always install the latest OS.
You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, click "SAVE" and then a window to a folder will pop up. It is probably a window to a folder that you download too. If so, you may want to change it and, save to this folder, "My Documents \ My TI Data \ Downloads". You can also go back and, download the Ti 84 Plus guidebook too, if needed. If your calculator will not turn on or, is locked up goto Procedure 2. Or else goto Procedure 7.
Procedure 7.
Link your computer and, Ti 84 Plus calculator with the USB cable or, Direct Black Link cable that came with the Ti 84 Plus calculator. Next, drag the Ti 84 Plus 2.55v MP OS that you saved earlier in "My Documents \ My TI Data \ Downloads" out of that folder and, drop it in the "Ti Connect" icon on the desktop. Click, "Continue" when the "Erase Warning" pops up and, the new Ti 84 Plus 2.55v MP OS will begin to install. Next, the Ti Device window should pop up and, highlight the port when it finds what your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
When the Ti Device Explorer finds and, highlights your calculator's information click, "Select." Then click, "Yes" when the next window shows up with your calculator's information and, the OS will continue to download. Upon completion the newest Ti 84 Plus 2.55v. MP OS will be installed.
If you run into any trouble with software or, drivers just comment to what failed at this posting and, I'll be glad to help you.
My TI-84 calculator lost its cover for the batteries. Since then it sometimes can't turn on or show anything when I push the button "on". But sometimes it still can work. But because I havent...
Hi twylazhangzh,
Sound like your Ti 84 Plus is really over loaded and, can't function properly. You can fix that by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you have a friend that has a Ti 84 Plus or, Ti 84 Plus Silver Edition you can connect the two calculators together through the IO link ports and, they can send you a copy of their OS while you receive it on your Ti 84 Plus. Hopefully your friend will have Ti84 Plus 2.55v. MP OS on their calculator or, it might not work.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer just keep following my instructions below.
First, you need to download and, install Ti Connect to your computer. If you don't need any help installing Ti Connect goto Procedure 1.
If your computer's OS is XP or Mac and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my XP or Mac OS". Just follow Procedure 1 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
If your computer's OS is Windows 7 and, you need instructions to download and, install Ti Connect click, "Install Ti Connect on my Windows 7 OS". Just follow Procedure 3 at that posting and, come back to this posting to finish downloading and, installing Ti84 Plus 2.55v. MP OS to your calculator.
Procedure 1 to installing Ti84 Plus 2.55v. MP OS
1). You can also get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
Next, the Ti Device window should pop up and, highlight the port when found that your Ti 84 Plus is using, USB1 cable or, Direct Black COM1.
1helpful
When ever i turn on my ti-84, it says waiting..... PLease install operating system now.
Hi biancaaii,
You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix the problem by installing the newest Ti 84 Plus 2.55v. MP OS. operating system.
If you can't find a calculator to connect to you can connect your Ti 84 Plus to a computer that has Ti Connect software on it. If you need to connect your Ti 84 Plus to a computer make sure the Ti Connect software is operating properly. You do not want any hang-ups while installing the Ti 84 Plus OS. Be careful, even a power failure during the process of installing the OS will destory your calculator.
Procedure 1 to installing the latest Ti84 Plus 2.55v. MP OS
1). You can get the latest copy of Ti84 Plus 2.55v. MP OS and, guidebook by going to the Texas Instruments web site. You can get to that site instantly by clicking, "Ti 84 Plus 2.55v. MP OS!" Once your at the Ti site click the Download Item, "Ti84 Plus family operating system". Next you can login or, click "continue as guest". I'd would click the "continue as guest". Once you have click, "continue as guest" the Ti84 Plus family operating system will download to you.
29helpful
4answers
Where is the equal sign on the ti 84 plus
hello sir, Press "second" "math", and it should be the first thing listed. If you need other commands hit "second" "0" that will enter the catalog and you can press any letter (without hitting alpha) to jump to that letter in the list. Please click on the following link to see the manual of the TI-84 Plus Calculator: http://education.ti.com/guidebooks/graphing/84p/TI84PlusGuidebook_Part2_EN.pdf
kindly rate me.. thanks for using fixya..
1helpful
Programming polynomial formula into the TI-84 SE
Check the link below
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=2#2
You may want to check the www.ticalc.org for the TI83. Programs are compatible. To put in your calculator, use the TIConnect software which you will find here.
http://education.ti.com/educationportal/downloadcenter/SoftwareList.do?website=US&tabId=1&paneId=7#9
Scroll down the page for connectivity software.
Hope it helps.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
